Results 1 to 6 of 6
Thread: Noise from motor
    VR Commodore Wagon
    Feb 2010
    Default Noise from motor
    Hi guys. I own a VR commodore and am experiencing a loud metal on metal noise coming from the motor every time i wind it over. I have had a mechanic friend have a look at it and he picked staright away, saying that it was the Harmonic balancer in the crank shaft. Im just after some advice on what is involved in replacing this part, and what tools you would recommend that i would need to do so? Cheers, David.
    VN Wagon
    Jan 2010
    you gonna need a new harmonic balancer obviously
    you need a decent breaker bar to remove the main bolt
    you also need to get a harmonic balancer puller to suit holden v6s most spares parts stores stock them there not to expensive.
    if you got some extra cash may aswell change the crank angle sensor saves pulling the balancer off again when it goes
    hope this helps cheers cam
    VR Commodore Wagon
    Feb 2010
    Hi Cameron, ok. i have taken the main bolt out from the centre of the crank shaft. What are the steps involved after this to taking the pulley off and replacing the CAS and harmonic balancer?
    Cheers,
    David
    VzVzVz's Avatar
    VzVzVz is offline <<< My Ride
    VZ S ute
    Jun 2009
    Port Melbourne
    Engine strip, by a mechanic of course. Big job, but prevents your engine from eating its self
    While you're there, you may as well get it balanced.
    VR Commodore
    Apr 2009
    Quote Originally Posted by eggman18 View Post
    Cheers,
    David
    You then need to use a 3 jaw puller to pull the balancer off the crank and behind there on the left hand side of the motor will be the crank angle sensor held by 2 screws. Unplug it and take the screws off to remove it. Put the new one in and new balancer. I recommend a rattle gun to do the balancer bolt up again. Make sure the slot on the new balancer lines up with the crank shaft slot. That's it.
    JD
    JD is offline Donating Member
    VS Berlina
    Aug 2006
    Deep South, SA
    Quote Originally Posted by v8freak55 View Post
    what? geez love to be your mechanic! i'd be a rich man!
    We got rep back, yaaay!
LinkBacks (?)
  1. can you fix old VN motor noise?
    By VNDUMP"D in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-05-2009, 11:09 PM
  2. Loud noise from motor, advice?!
    By Wagon_Wheel in forum General
    Last Post: 12-01-2009, 07:20 PM
  3. 'Grinding' Noise from motor
    By alex2_s in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-11-2008, 09:17 AM
  4. motor ticking noise
    By creamy in forum VL Holden Commodore (1986 - 1988)
    Last Post: 26-06-2008, 12:50 PM
  5. Noise from front of motor
    By DUMPD_VP_CALAIS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-08-2005, 11:34 PM
