Results 1 to 6 of 6
Thread: vs berlina starter problem
    vs berlina
    Feb 2010
    Default vs berlina starter problem
    car wont turn over but starter motor clicks, battery is charged terminals are tight, was working awhile ago but has been sitting for a month or 2.....do i need to replace the starter motor?
    Vr ss & vy v6 wagon
    Jan 2010
    Central Coast, NSW
    are you sure the battery is charged? maybe sitting so long drained it then killed it so as soon as you turn the key it takes all the power out of it?thats what it sounds like if the starter clicks
    vs berlina
    Feb 2010
    not the battery, replaced with brand new battery. the starter motor just clicks once......
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Check the starter motor connections to make sure they haven't corroded. Check the voltage at the starter motor to make sure the current is getting through.
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    As above and make sure the nut on the starter solenoid (at the end of the battery cable) is not loose.
    vs berlina
    Feb 2010
    the starter was bugged got a new one there but now the dashlights flash on and off when i turn it over i think its my fusable links ?
  1. Starter problem
    By tandan in forum Electrical Wiring / Questions
    Last Post: 03-01-2010, 08:34 PM
  2. Vt ss 5.0l starter problem
    By burto8 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-10-2009, 05:41 PM
  3. starter problem?
    By vpcommo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-06-2009, 09:47 PM
  4. Possible Starter Motor problem
    By VT Dave in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-11-2006, 11:31 PM
  5. Starter Motor Problem (VP)
    By kennedymr in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-06-2005, 07:21 AM
Tags for this Thread
