Results 1 to 4 of 4
Thread: Vs manual to auto engine??
    bhagl1 is offline Brendon
    96 3.8L VS Ute
    Oct 2008
    Default Vs manual to auto engine??
    I recent spun the big end bearing in my 96 vs 5 speed,
    i took it to get a new motor put in it,
    the new motor is an auto motor and my mechanic said that i need a manual motor cause the auto wont fit the crank or something is that right?
    Thanks Brendon
    Mar 2008
    the flywheel will bolt up to the auto crank ok, i think what your mechanic is meaning is the auto cranks dont have any holes for dowell pins as used in the manual flywheel
    your mechanic could probably get the dowell pin holes drilled into the auto crank
    have a read of the link below
    V6 Crankshaft Info
    Exedy solid flywheel conversion for VS V6 getrag... need help ASAP
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Just out interest, how did you spin the bearing - how many K's, overheat?...oil used etc etc.
    Thanks.
    96 3.8L VS Ute
    Oct 2008
    only had 89,000 on it dont think they must of been genuine but, it started heating up alot before it happened.
  1. manual v6 vn engine is different to an auto vn v6 angine??
    By kwik6 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-05-2010, 08:55 PM
  2. vs v6 manual engine same as auto engine
    By benno86 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-11-2009, 08:03 AM
  3. VR Auto - Manual Engine - any differencies?
    By Machineage in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-03-2009, 05:03 PM
  4. Can auto engine go on manual box
    By spunkykpc in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-11-2008, 01:05 AM
  5. vn v6's auto manual different engine?>?
    By kwik6 in forum V6 Development And Modification
    Last Post: 09-04-2006, 10:08 AM
Tags for this Thread
