this is a common problems with the VR's i believe it is a disconnected line near the back of the AC controls, hopefully someone else will post with a bit more knowledge.
I am sure this has been covered before... please do a search.
Hey all,
Recently ive been experiencing water flowing and pooling near my feet when i drive my VR commodore. This normally happens when i turn left more so. It may be from the airconditioning as im also experiencing problems getting the aircon to regulate from the top of the car, to just the feet, the dial doesnt seem to be working. After i pulled it apart i realised there wasnt enough vaccum being produced. Any ideas on how to fix either problem would be greatly appreciated =D
Daniel.
-Smit
You might also need to check that none of the vacuum lines are split and leaking or dislodged. Locate the vacuum hose where it foes through the bulkhead and remove it with engine idling to see if there is a high vacuum....if not trace back all the way to the black plastic vacuum reservoir under the passenger side guard (front).
Welcome to the forum as well!
