Can anybody give me a definate answer on fitting a vs ecotec engine auto into a vr auto
this is what i think i need
Vs engine with loom ,ecu bcm and key heads to fit on my key,
Vs gearbox as i believe the vr has 12 pins and the vs has 13 pins
will the vs engine mounts bolt up in the exact same spot as the vr
same goes for vs gearbox will it bolt up to the existing mount holes
is the tail shaft the exact same length on both the vr and vs
are the cooling pipe the same size bolt up on the box
is there anything else i will need or wont need
thanks guys
