Results 1 to 3 of 3
Thread: VS door window rubbers
    VS S2 Acclaim
    Apr 2005
    Default VS door window rubbers
    Hi Fellas,
    I've tried searching for a thread to help me replace door window rubbers but can't find. Mine are starting to fall off and disappear inside the door. You know the rubber that sits on the inside part of car door where you usually rest your elbow when the windows down. The rubbers look similar to wiper rubbers.
    Is there a thread already up which someone could redirect me to or explain to me how to replace these rubbers. Do I need to buy new rubbers or can the ones already there be refitted. I hope it's not the case but it looks like I might need to remove the whole door trim to reset the rubber/seal
    Thanks in advance for your Help
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I remember this being covered quite a few years ago. The easiest fix was to retrieve the rubber strip and glue it back on....however it eventually falls off again. Most people live with it.
    VS S2 Acclaim
    Apr 2005
    Thanks Hako
LinkBacks (?)
  1. VN Door Seal Rubbers
    By stockies in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-12-2007, 02:44 PM
  2. Door Rubbers
    By wooly72 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-11-2005, 10:28 AM
  3. Door rubbers on my Vl Commy
    By Cherrys in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-07-2005, 08:28 PM
  4. v.s door trim and relacing window sil rubbers
    By camara in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-03-2005, 03:23 PM
  5. Door Rubbers
    Last Post: 22-11-2004, 08:25 PM
