Results 1 to 6 of 6
Thread: vs - vx engine?
    bhagl1 is offline Brendon
    96 3.8L VS Ute
    Oct 2008
    Default vs - vx engine?
    Just wondering what the difference between a vx and a vs engine is? I blew my manual vs engine up and bought a manual vx engine to swap into it.
    Thanks Brendon
    Dec 2009
    I think there may be slight differences to the inside of the inlet manifold and other small things to improve it's economy. I don't know if any of the connections are different or anything like that, the ECU in a VX may be more powerful and/or have a different tune but if the plugs are all the same I'd imagine you could swap it over and it would work.
    96 3.8L VS Ute
    Oct 2008
    yeah i have changed the inlet manifold over, but it didnt come with an ecu so should my vs one work?
    Thanks Brendon
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Might be an idea to use all the sensors from the VS.
    VP BT1 & BLOWN STATESMAN
    Oct 2005
    Just use the wiring from your vs, the only thing you have to change is the top section of the manfold and also the exhaust manfold (EGR)
    note vs and vt a/c are diffenernt too
    NEVER LATE IN A 355ci
    Mar 2008
    i think you will find the plugs on the ecu and loom are different between the vs and vx
    i dont know if your vs loom will plug into all the vx senors ?
  1. Engine died at 100kmh then check engine light up ?
    By calaismity in forum VE Holden Commodore (2006 - ?)
    Last Post: 17-05-2011, 09:58 AM
  2. vs 304 (5.0L) engine wiring diagram - engine dyno runs
    By chez00 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-11-2009, 03:00 PM
  3. help needed identifying an engine based on the engine number
    By V6_Lux in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-02-2008, 01:25 PM
  4. VN Engine - Signs of failed engine valves
    By nolim8ts in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-04-2007, 07:15 PM
  5. ALOT of engine movment... not broken engine mounts
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:14 AM
Tags for this Thread
