Results 1 to 4 of 4
Thread: over charging?
    vr Executive 3.8
    Feb 2010
    Exclamation over charging?
    hi i got a vr 3.8 that the battery light stays on unless idleing its putting 18-20 volts! what would the problem be?and where is the regulator located?
    vs commodore
    Oct 2009
    Tamworth NSW
    The voltage regulator inside the alternator sounds like its stuffed,they can be replaced,or you can just replace the whole alternator with a reconditioned one.If the voltage reg is gone the rest of the alternator is probably just as worn out.(bearings etc).
    vr Executive 3.8
    Feb 2010
    would the regulator be that black thing that gets pluged into on top at back (alternator is in good con)
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    As above, the regulator is mounted on the rear of the alternator and is the cause of the problem.
    18-20V!!!!
    That burning smell is your PCM and BCM!
  1. Not Charging
    By ])R@G()N in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-02-2010, 01:41 AM
  2. turbo charging vr v6
    By pen15 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-02-2008, 01:56 AM
  3. charging the v6 auto...
    By lumina01 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-10-2007, 12:25 AM
  4. charging a battery
    By cladiges in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-09-2007, 09:53 PM
  5. charging
    By Mr Ute in forum Yella Terra
    Last Post: 27-04-2007, 03:29 PM
