Hey guys i was wondering if anyone knows of ways to increase my torque/accell.
it has a tuned memcal in it but i just seems to lack... i dont no if i was just expecting to much out of the manual conversion and chip but yeh any ideas would be a great help./
Thanks
Sounds like you should try some different diff gears,try a lower ratio,it will give excellent pickup,but it will loose some top end speed.
what sort of chip was it
its a reprogrammed factory chip. programmed with genuine delco software. you think this could be an issue?
yeh i have though of diff gears but the lsd was rebuilt recently and its a lot of money to redo.. seems a waste...
yeh but to change the gears dont you have to pull apart the lsd centre...? then i have to get it rebuild.. again... i think i need a to get one of those money tree things.
You wont have to pull apart the centre, but you will need to get it all re-shimmed which is expensive.
yeh. once again money tree. how far can i change my ratio before it puts speedo way out and such. like 3.45 3.55 3.7 3.9 4.11?
other than that. any other ideas
buy a V8...........
started to build one.
but i have those stupid little p plate things in my windows
did you do the manual and chip at the same time maybe the chip isnt that great be an ebay one by the way you described it being tuned with delco software like the guys ebay add LOL
yes i did the chip and manual at the same time. well im just going by what he said, maybe im just a little bit to trusting. hoping he was legit. can i get the chip check to see if its any good, or just try again?
