Results 1 to 14 of 14
Thread: aircon fuel consumption
    '97 VSII Executive V6 Auto
    Aug 2009
    sydney
    Default aircon fuel consumption
    any idea how much fuel the aircon uses?
    I used to get around 10-12L/100kms without aircon, which needed repairing, then, when i fixed it, I get aroun 12-14L/100kms for the same driving in the same climate.
    I do use it quite a bit i have to admit.
    does this seem normal for a VSII ecotec NA? yesterday it even touched 14.2L/100kms!!!
    vs calais
    Dec 2008
    hi mate, what average speed do you have with that usage??
    seems good to me, mine sits around 16.5/100km
    vs series 2 v6
    VP Exec
    Jun 2005
    You'd have to do a back to back to be sure - couple of tanks with A/C, a couple with it off but that doesn't seem an unreasonable difference.
    The amount of extra fuel used with A/C depends on ambient temp., trip time - the A/C will cycle off for longer when maintaining temp. than it will while reducing it, vent control position and fan speed. Recirc. and low fan speed will reduce the fuel used over fresh and high fan speed. Shutting vents so as to direct air to only occupied seats in the car will help also.
    pmlegend's Avatar
    pmlegend is offline pmlegend
    VS Series 2 Wagon
    Dec 2009
    Collarenebri
    I did over 5000 km last month with ac going most of the time. Mixture of city and open road driving and averaged 10.8l/100km.
    Aug 2009
    sydney
    I do a mixture of city and urban driving, including several times in peak hour.
    my aircon was stuffed for three months, and then i got it fixed. my driving hasn't changed, it's still the same going to work and back, only difference is the aircon is on...
    I usually set it to recycle air, speeds 2-4
    vs calais
    Dec 2008
    Aug 2009
    sydney
    you mean km/h? or speed setting...
    my average fan speed is 2, sometimes 3
    i do about 70%city and 30%highway/open road...
    vs calais
    Dec 2008
    Aug 2009
    sydney
    vs calais
    Dec 2008
    ye but wen you say u get 14.2L/100km
    wat avg speed does your trip meter say?
    Aug 2009
    sydney
    Quote Originally Posted by admir87 View Post
    lol, it's an executive... i only have the speed alert
    vs calais
    Dec 2008
    Aug 2009
    sydney
    well, divide the number of liters used by the number of kilometers and then multiply by 100 lol
    simple mathematics.
    I always fill up to the same point so i'm quite accurate.
    ORIXVywags's Avatar
    ORIXVywags is offline Max stunners on the train
    VYII Acclaim,VR Acclaim,VS Ute,VS Berlina Wagon
    Nov 2008
    Sydney, Hurstville Grove /Shire
    I recently did a bit of work on my car inregards to my Valley Gaskets,
    I used to drive a lot with Air/Con on Auto due to it being a Berlina, mainly because it works extremely well once the inside temp cools to the desired temperature (mostly 19c - 21c) considering its a Wagon
    Before doing valley gaskets I noticed a giant drop in performance with A/c on (only should be a small drop) and i was using 14.2L whilst in City and 10.8L on Highway
    Now that the Valley's are done, and after hitting "Auto a/c" there isn't a much difference to performance, and its doing 13.1L per 100 in City, and best ever on the Highway was 9.2L and not having A/c on I got an amazing 8.7L on the Highway
    My mechanic says that due to the better AirFlow and the minor increase to compression the motor doesn't have to work as hard to keep a nice Pressure, ultimately dealing with A/c Better
    This isn't always the case said my Mechanic, but it is something to think about, he did say that my Valley's were the worst he has seen in while and Oil was making a pretty good attempt to make its way out,
  1. Fuel Consumption
    By VesperZ in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 29-11-2009, 09:22 AM
  2. Fuel Consumption
    By Acclaim96 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-06-2009, 09:00 PM
  3. vt/vx fuel consumption
    By cruzn in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-09-2006, 12:46 AM
  4. Fuel Consumption.
    By stono in forum VY Holden Commodore (2002 - 2004)
    Last Post: 28-07-2006, 03:32 AM
  5. Fuel Consumption
    By IVICA in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-08-2005, 10:53 AM
