+ Reply to Thread
Results 1 to 3 of 3
Thread: Water leak
    VP waggon
    Feb 2010
    Default Water leak
    I have just started getting cold or room temperature water leaking onto my left foot when I go round a left hand bend.
    It is distracting at the wrong moment and of course dangerous.
    Although I have a dickie back I have tried pulling the centre dash console out to see where it is coming from to no avail.
    Anyone out there have any hints or suggestions ???
    mischa's Avatar
    mischa is offline Mmmmm, 4 bolts.... mischa Calais
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    Dose it do it after running the AC?
    The Daily VN T5V6
    355 VN GRP A REP
    hako is offline Donating Member hako Senator hako Senator hako Senator
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    It will probably be the A/C drain tubes blocked - they drain the water that the A/C evaporator extracts from the air as it cools it. Have a look under the car about the middle of the gearbox and you will see where the tubes exit - clean with a long cable tie. With your dicky back I'd guess you will need to get someone else to have a look for you.
+ Reply to Thread
  1. Water Leak
    By hN! in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-11-2009, 10:47 PM
  2. water leak
    By willsV8 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-09-2009, 06:43 PM
  3. 253 water leak??
    By jimmyd17 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-04-2009, 04:02 AM
  4. Water Leak...
    By VPplayer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-04-2009, 01:57 PM
  5. water leak
    By newbee in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-07-2008, 06:44 PM
Tags for this Thread
