Results 1 to 7 of 7
Thread: speedo problem help me!!!
    vs wagon
    Feb 2010
    Default speedo problem help me!!!
    hello everyone i need some help i have a 95 vs wagon with just the standard donk and a t5 gearbox on her and i have bought a 99 vs ute with yeah a few engine mods and a getrag gear box...
    anywho ive swapped it all over ironed out all the issues except one the SPEEDO! now ive looked everywher on the net but no one seems to have done this gearbox swap that i can find ,, there are different plugs on the box so i pulled the wirin to the box out of the ute and plugged it in and ran it to the computer and made it work there and was hoping for it to work..... mmm no it didnt, theres two different plugs on the box but one of them should be working fine whatever it does i just changed the style of plug on the wire and plugged it in but yeah this new box on the old wiring loom it has 3 wires and the new one only has 2 wires so yeah i cant just change the style of it if u get what i mean???
    now if anyone could help me it would be muchly appreciated just ask me if you have any questions bout it ... i prolly didnt explain it real awesome but yeah see if u could help me?? cheersss matty.
    vs wagon
    Feb 2010
    anybody know anything on it at all????? or send me in the right direction possibly? cheers,
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If it was me, I'd start with a wiring diagram for both the wagon and the ute. Otherwise you are just stabbing in the dark.
    Not sure where you can get a ute wiring diagram but the wagon is in Gregorys at your local library.
    vs clubsport
    Mar 2009
    brisbane
    well what did you swap over because getrag computer wont read speedo output from t5 and vice versa same as with the auto's they use a different way of sending pulses to the ecu
    Float like an elephant sting like a tree clubsport hits what doug does'nt see
    vs wagon
    Feb 2010
    ah k k yeah i mite try and get onto a set of wiring diagrams,, yeah i swapped the computer from the ute into my wagon too but yeah still unsure of where to go with it,,,, cause yeah i have the new cable installed from the box to the new computer but now i guess it needs a wire from the computer to the dash or somethin??
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    sure does theres a violet wire to the dash from the ecu the T5 runs 3 wires from the sender power earth and signal the signal goes to the ecu pin and is then sent to the dash the getrag has 2 wires going in and one out to the dash my bet is its in the wrong hole for the dash wire
    vs wagon
    Feb 2010
    Quote Originally Posted by delcowizzid View Post
    sounds alright what cha sayin bruv but have you possibly got any diagrams ha know im askin for a bit lol but yeah not sure where to look been looking for diagrams on the comp and cant find anything???? cheers for ya help anyways dude...
  1. vn speedo problem
    By Browny_226 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-05-2010, 06:31 PM
  2. rev and speedo problem
    By clazy69 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-03-2009, 02:31 PM
  3. speedo problem
    By vkhawkey in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 13-10-2007, 10:59 AM
  4. VR speedo problem
    By bezclez in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-04-2007, 12:14 PM
  5. speedo problem
    By Matagi in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-07-2005, 01:57 PM
