Results 1 to 12 of 12
Thread: vr berlina odometer
    Vr Berlina
    Jun 2009
    Default vr berlina odometer
    hi all,
    i have been having a problem where the odomter resets it self to 555,555
    after a while the odomter would go back to the original reading, last week it jumped up to 555,555 again, it would not go back and the kilometers kept on building up!
    today i pushed in the odometer and was able to get it to reset to 555,555 but then it went back to the origianl number of kilometers but this time it was 555,670 so now it is stuck on that reading! any help please!!!
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    i would remove it and send it off to a repair place, sounds like a intermint short in the dash
    Vr Berlina
    Jun 2009
    yeah man i rang gauge works down here in geelong and he said to try find a second hand one and he can re program the kilometers on it! so i just gotta find one asap!
    2004 XR6T & 1990 VN dragcar project
    Jan 2010
    Bendigo, Victoria
    This is a common problem with them. Though I can't remember exactly why it occurs, you can get someone to reset it though (as its a lvl.3 cluster, yes?)
    Vr Berlina
    Jun 2009
    yeah i am assuming its a level 3 cluster as it has the three windows down the bottom.
    if i push it in hard then it resets so could it be the loom or a cable is not plugged in properly??
    Vr Berlina
    Jun 2009
    hey everyone,
    i found a level 3 dash that look sidenticle to what i need, but its out of a vp berlina or a calais? cant remember, any ways would that still fit with all the looms and such?
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    not sure if you've tried this but reset your ecu, take the battery off for a good 10 minutes or so.
    moff_man's Avatar
    Nov 2008
    Quote Originally Posted by rowinskii View Post
    hey everyone,
    no there diffrent dashes
    Jul 2008
    I have a spare working Lvl 3 cluster from a VR berlina. Pm if your interested.
    Vr Berlina
    Jun 2009
    Pm'd...
    i cant wait for it to read normal again, and having so many kilometres showing wil not help it sell!
    Vr Berlina
    Jun 2009
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Any VR/VS trip computer will fit your cluster. easy swap and then you wont have an issue with the V8 tacho.
    The 555,555 is a default reading when the ODO chip is replaced or fails to read properly. If you take the ODO chip off the PCB it will show 555,555. It's a security aspect of the trip computers to stop people from changing the ODO chip on the PCB as the check sum is not correct for that trip computer.
    and 3 Dangerous non ABS VN's
  1. Vr berlina Odometer Jumped to 500,000k's! Help!
    By rowinskii in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-12-2009, 09:07 PM
  2. VK Odometer
    By patullose in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-09-2005, 11:11 PM
  3. VR Berlina Odometer reset
    By colgreen in forum Electrical Wiring / Questions
    Last Post: 30-03-2005, 12:08 PM
  4. Odometer
    By red rock in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-05-2004, 10:10 AM
  5. odometer
    By Garth in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 08-05-2004, 09:39 AM
