Results 1 to 6 of 6
Thread: weird behaviour with engine warning VR V6
    VR Calais
    Aug 2009
    Default weird behaviour with engine warning VR V6
    This behaviour is very puzzling ...
    If I drive off from cold, and get straight on the motorway and just keep going, the engine warning light doesn't come on.
    But in normal driving around town, it'll come on after about 6 minutes or so.
    Checking the codes, I get the following:
    12 (OK!), 43 (knock sensor) , 44 (oxygen sensor) & 56 (lean under load).
    Seems to me if those three faults are genuine, the engine light should always come on ...
    Anyone struck this one before?
    vx s pack II
    Jan 2010
    aLKIDA
    vy 5.7 calais
    Mar 2009
    the reason it comes on after it warms up is when it is cold it is in open loop and the PCM ignores the oxygen sensor readings. it could also be a vac leak after the throttle body that shows up as oxy sensor fault.
    VR Calais
    Aug 2009
    Yes it was the oxygen sensor. City fuel consumption now down from 15.5 to 11 L / 100km!
    vr stroker v6
    Jan 2009
    townsville qld
    VR Calais
    Aug 2009
    Thumbs up
    Yup - that's what I did and it brought fuel consumption down by nearly a third, and engine warning light is now off. Thanks for the tips.
  1. Weird Noise in Vp 93 Engine
    By Auzzie_VP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-08-2009, 02:04 AM
  2. Weird Stereo Behaviour
    By cadburyvx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-12-2007, 10:35 PM
