Results 1 to 23 of 23
Thread: performance fuel filters?
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    Question performance fuel filters?
    hey just wondering what the best brand fuel filters are? (for buick v6)
    or is it just whatever, doesn't really matter.
    strgas's Avatar
    strgas is offline GRA = REAL HP
    Oct 2009
    filters are filters its the quality of the fuel and tank condition and how often you change them , drive your car around on low fuel often enough and crap build up will increase , moisture build up inside the tank can accelerate surface rust which will flake off and clog the filter quicker .
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Quote Originally Posted by strgas View Post
    thanks for that how can you check/clean moisture in your tank?
    strgas's Avatar
    Oct 2009
    Take a fuel sample from your tank in a clean glass bottle and allow it to sit for awhile you will see any debris or moisture will settle to the bottom , there are fuel conditioners available from marine shops which can help with moisture break down , for a daily driven car moisture build up in the tank isnt that much of a problem its when the fuel tank sits idle for sometime with low fuel levels . check your tank breathers and vents and seals .
    2000 VS Ute 5 Speed
    Oct 2008
    Western NSW
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    how do I take a sample? where are the tank breathers/seals?
    excuse my lack of knowledge lol
    strgas's Avatar
    Oct 2009
    fuel sample can be taken in many ways , removing fuel line from rail supply or return line will do , disconnect fuel filter , jiggle hose down the filler neck , breather lines are located behind the tin plate in the drivers rear wheel arch and also run to the charcoal canister under the bonnet , check your cap seal for condition , check the vacum lines from the engine to the charcoal canister for signs of cracking or blockages .
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    strgas's Avatar
    Oct 2009
    For a standard car a simple ryco filter would do the job fine .
    FUEL FILTER & WATER SEPERATOR KIT FOR HOLDEN FORD CHEV = wank factor for street use
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    lol. extra performance would be nice, do you think it would help the fuel system?
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If you use E10 fuel, the ethanol in the fuel absorbs any moisture in the tank. Back a few years, if we had water in the fuel we would add about 1/2 a litre of methylated spirits to the tank....the metho absorbed the water and mixed it with the fuel. Ethanol is more or less the same animal as metho.
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    AC delco fuel filter = win.
    strgas's Avatar
    Oct 2009
    no gains to be made here on a std car with a std fuel system ...
    strgas's Avatar
    Oct 2009
    AC DELCO $$$$$$$$$$ profit profit profit
    Ryco inexpensive and reliable
    regular filter changes is the key not the cost of the filter ???
  15. #15
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    noted. depends what the price difference is in whatever auto shop i end up buying one from. thanks for your help everyone.
  16. #16
    vs2 berlina 96 3.8 auto hsv plated
    Sep 2008
    brisbane nth
    I want to change fuel filter on VS 6/96. Never done myself before. Hoping someone could guide me - talk me through please...
    Reason being - the cars keeps stopping. Sometimes won't start. I wait for 5 mins and then it goes. Have changed the computer. Crank angle sensor maybe needs doing. Any thoughts ?
    Any other ideas re this stopping please?
    Kind Rgds
    Dave
  17. #17
    vs commodore
    Oct 2009
    Tamworth NSW
    To change the fuel filter let the engine idle ,and whilst its idling remove the fuel pump relay from the fuse box under the bonnet.The engine will then stall ,then wind it over for another 5 seconds or so.This procedure drops the fuel line pressure so it doesnt spray into your eyes or what not when the filter is removed.Then install the new filter,install the relay again and start the engine,check for any leaks around the new filter.Too easy.What you have said points to the Crank Angle Sensor (CAS).Replace it.Also do en error check on the engine management system.Heres a link to show you how to do this. Checking error codes VR/VS (Revised) The top post in this link explains how to do this test,and if you scroll down near the bottom of the page theres some excellent pictures which shows you how to do it.
  18. #18
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
  19. #19
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    ryco filter FTW
    Body by Holden, Soul by Brock
    the Legend will live forever
  20. #20
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
  21. #21
    Sep 2008
    brisbane nth
    Thanks for info on fuel filter change. I see that last change done 3/09. What would be suitable interval for fuel filter change?
    Tks
    Dave
    6/96 VS
  22. #22
    vr statesman 5.0 + vs exec s2 auto
    Mar 2006
    central coast, nsw
    Quote Originally Posted by trip01 View Post
    Tks
    Dave
    6/96 VS
    pretty sure its 2 years or 40000 kms thats from the GREGORY`S VS manual.
  23. #23
    RX25SE's Avatar
    vsII acclaim wagon
    Jan 2009
    Our fuel can be a bit crappy.
    I do mine every 25000kms and use AC Delco
  1. VS and VT Fuel filters - are they the same???
    By majac in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-01-2010, 06:18 PM
  2. performance fuel filter
    By myvq5ltr in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-04-2007, 07:25 PM
  3. performance fuel filter
    Last Post: 28-03-2007, 03:57 PM
  4. What oil & fuel filters do you use?
    By Charg'd in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-02-2007, 08:13 PM
  5. Fuel filters
    By sexcvn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-05-2006, 08:20 PM
