Results 1 to 16 of 16
Thread: Rear main seal
    VS Commodore
    Oct 2008
    Default Rear main seal
    hey all ive jus found out my rear main seals leaking, jus wondering if anyone knows where i could get it fixed cheapish?? its for a 95 vs wagon, thanks!
    Wombles's Avatar
    Wombles is offline Cars cost too much.
    1995 VS Acclaim
    Oct 2009
    Just go around to all nearby mechanics and get quotes. It will be like a $600 - $700 job possibly.
    Not cheap!
    My way of doing it cheap is getting a friend of mine to help me and do it in my garage with the car on stands and ramps. :P
    http://forums.justcommodores.com.au/...e-acclaim.html
    My Commy
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.
    Discuss.
    VS Berlina S2
    Feb 2010
    Gearbox has to come out........not a quick cheap fix. Price will also depend on whether you decide to just replace the seal and gasket or the whole rear main plate on the V6. Is it bad or can you live with it?
    VS Commodore
    Oct 2008
    my mechanic sed i can live with it but u kno its prolly gna get worse sooner or later.. he sed its mainly jus gna cost me in labour, the seals f*ck all.. is ther anyone out ther that'll do it cheap lol..
    VS Berlina 3.8
    Dec 2008
    sed? u? kno? gna? sed? jus? gna? ther? You'll get a better response if you write in English.
    It would probably help if you told people where you live too, but your best bet is for you to go and get some quotes from places around you.
    VS Commodore
    Oct 2008
    its pretty simple to read if ur not retarded.. if ur gna pick on the way i type u can pretty much jus fu*k off.. ur not helping anyone..
    Mar 2009
    VS Commodore
    Oct 2008
    VS Berlina 3.8
    Dec 2008
    Quote Originally Posted by supaushh123 View Post
    Pretty simple to spell if your not retarded too... All I was saying was that you will get a better response when people don't have to decipher what you're saying. You can take it on board if you want to or not.
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Pretty sure the name calling is not needed.
    Also... typing 'f*ck' counts as bypassing the swear filter, so may want to cut that out too.
    VT V6 Manual
    Apr 2009
    anyone in adelaide that mite wana do a cashy?
    Ahh that explains the language barrier then.
    Coming in to ask for help and then telling people where to go isn't going to get you any favours mate.
    VYII Acclaim
    Jun 2008
    Largs Bay, Adelaide, S.A
    Hey you, back off! I'm in Adelaide.
    VYII Acclaim
    Jun 2008
    Quote Originally Posted by Jesterarts View Post
    Pointing out that typing 'f*ck' counts as bypassing the swear filter, while actually typing 'f*ck' in your own post made me laugh.
    DannyboyDS is offline Just hand me the pliers.
    VS Berlina
    Feb 2007
    for crying out loud, is this what the forums have come to?
    If you can't read his post, move on to another one.
    What you will need to do mate is use the search function a little :P there are a number of threads for the removing of the auto, if you have a manual there are a number of threads for the removing of a manual too.
    Then search rear main seal there are a few good and detailed threads on that, the advice i'll give you is check that it's not your valley gaskets from up higher, go to the carwash, degrease the heck out of the engine bay and around the top at the back too.
    Once its all clean drive it for a day or so and then try to trace the oil back to it's source.
    Oh and if you do pull the gearbox out and replace the seal go to holden and get the seal AND the plate that it sits in together, use some silicone around that plate when you install it and make sure the crank is clean and free of any little sharp edges, I have done this a few times now and have finally got it down pat.
    Let us know how the engine cleaning goes. Oh and for the record it MIGHT get worse but 90% of v6 commodores have a rear main seal leak and it's 99% more of a slow seep.
  15. #15
    vs clubsport
    Mar 2009
    brisbane
    ha rear main seal leak the 304's left the production line leaking oil
    Float like an elephant sting like a tree clubsport hits what doug does'nt see
  16. #16
    VS Berlina
    Feb 2007
    Quote Originally Posted by clubby_you View Post
    hey good point, is it a 6 or an 8? different style seals. I was tlaking about 6's
LinkBacks (?)
  1. 304 rear main seal??
    By fatty1 in forum V8 Development and Modification
    Last Post: 18-10-2008, 10:08 PM
  2. Rear Main oil seal AGAIN
    By LisnM8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-07-2008, 05:48 PM
  3. rear main seal
    By defa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-01-2007, 11:22 PM
  4. Rear main seal
    By mouce in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-05-2006, 03:45 AM
  5. rear main seal
    By markovr in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-07-2005, 02:38 AM
