Results 1 to 6 of 6
Thread: Haltech Aircon
    1995 VRII Wagon
    Feb 2010
    Gosnells
    Default Haltech Aircon
    Hey guys,
    Have a VR 5.0 manual, and have a haltech installed (E6GMX).
    Just wondering if any of you have a haltech E6GMX installed and if you had any issues with airconditioning afterwards?
    Any info would be great.
    Thanks
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    ECU has nothing to do with the aircon.
    Someones ****ed something up while putting your haltech in.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    Mar 2009
    pretty sure ive read somewhere they can stop your air con working... best wait for greenfoam to tell us if it does or doesnt ;-)
    s1 vt
    Jul 2005
    when the aircon is on the ecu increases the idle to compensate for the load associated if your install of the haltech wasnt done correctly to address this then it could be the only problem. otherwise everything else is mechanical.
    Mar 2009
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    the delco controls the A/C more than you think it cuts it out at certian revs to save it dieing from spinning to fast and all sorts of things obviously its not been hooked up or setup in the ecu.i would of left the delco in there
  1. Help E6gmx Haltech
    By redvsberlina in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-01-2010, 08:22 PM
  2. Looking for haltech base map vn v6
    By needwork2-4fillhabbit in forum Tuning
    Last Post: 29-10-2009, 06:28 PM
  3. Haltech E6X
    By 96SEN8R in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-10-2008, 12:29 AM
  4. Haltech E6h
    By XMY308 in forum Electrical Wiring / Questions
    Last Post: 05-06-2008, 02:21 AM
  5. wiring a neon to the aircon switch to show that the aircon is on
    By 12000 in forum Electrical Wiring / Questions
    Last Post: 25-03-2007, 08:44 AM
