Page 1 of 2 12 LastLast
Results 1 to 25 of 30
Thread: Vs ute fuel pump
    VE SV6 Commodore Ute
    Aug 2009
    Default Vs ute fuel pump
    Hey guys I'm just wondering where the fuel pump is in the vs ute. I broke down on pennant hills Rd this arvo.it was bulls?&$. All it's doing is chuging before I broke down my foot was flat to the ground and I was doing 20ks. Please help... And is it easy to put in myself?
    Holden VS Series II 1997 Ute - 5 Speed Manual
    Aug 2008
    Quote Originally Posted by lclynch View Post
    Fuel pump is in the tank under the tray. Best to get a gregorys manual or similar.
    Aug 2009
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Are you sure it is the fuel pump that's buggered - when they fail it is usually a complete stop as they either work or they don't.....maybe it's just the fuel filter.
    Aug 2009
    im not sure, i just have a feeling its not getting enough fuel thats why its chugging and it stalled and would start again. the tank was full and i never run it below 1/4 maybe i should do both?
    Aug 2008
    Dont do both lol, do one at a time so you actually find out what the problem is
    Aug 2009
    If it makes any difference when it stalled I stomped in the tray above the fuel tank and it started again. But it was still chugging
    Aug 2008
    Lol, well im guessing it may have something to do with it, but as was said above usually these pumps just cark it, not a slow death, although i know a m8 that went through everything on a vs sedan and it ended up being the fuel pump after 300,000kms.
    Aug 2009
    Yeah well I just brought a fuel filter and I'll throw it in and let you know. Thanks
    A bicycle
    Aug 2009
    Gippsland, Victoria
    make sure you get a genuine pump if you find out thats the problem, the non genuine ones are not the same and i still had the same problem you had until i put a genuine one in there.
    does it die when you go around right hand corners with a bit of speed too with a low fuel load?
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Quote Originally Posted by NonStick Squid View Post
    @old mate you drive a vs ute therefore you're a bogan therefore your point is invalid
    vr commodore ute series 2
    Feb 2010
    iff the fuel filter is dodgy it wont cuase the car to do as your saying its doing. honestly im a mechanic and unless you know what your doingthe fuel pumps are a real basterd to fit
    Aug 2009
    Yeah sometimes it did die going around corners wit 1/4 tank. I just put a new filter in it and it was good. I drove around the block twice and now it won't start again. Maybe it's my injecters
    Aug 2008
    HAHA, you sure you have got sufficient fuel in the tank and the gauge isn't farked?
    Aug 2009
    Yeah it's all good I filled it yesterday it's showing it's 3/4 full. I'm so pissed I don't know what to do , I know I'm gana need to get a fkn mobile mechanic out.
  15. #15
    vs 5L ute and vh project
    Evel Cownievel Champion!
    Dec 2008
    NSW inverell
    my ute started 2 run like a dog befor the fuel pump went, then i went 2 kick it over it wouldnt start then i was lissing for the fuel pump and nothing so i changed it ova was fun trying 2 get it out then i spent 30 mins trying 2 get out the filter off the old pump i droped in the tank but fixed the problem
  16. #16
    VT
    Apr 2005
    QLD
    you stomped on the tank and it started again.
    Vapour lock in the tank?
    Take the tank cover off, turn the car to 'ON', can you hear the pump prime for a second or so?
  17. #17
    Aug 2009
    Yeah, I jumpped in the tray and stomped ova the tank and it started but not well. And just then I started it but was chugging hard and when I press the excelerater it sounded like lots of air was coming outta the bay and it made things worse. Maybe I just need a pump ... When I put it to acceseries it kinda buzzes like a zzzzzz. I've heard it's mention to tick?
  18. #18
    vs commodore
    Oct 2009
    Tamworth NSW
    If the fuel pump is priming for 2 seconds when the key is turned to on,it is more likely to be a blocked fuel filter.Or it might be the fuel pressure regulator.I just read that the filter was replaced and it went good for a while,it might have dirt in the tank.
  19. #19
    Aug 2009
  20. #20
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    not your injectors, for that to happen more than one would need to stop working at the same time. Your car will still run on 5 cylinders. You got more chance of winning lotto than finding your injectors being the problem.
    Change your pump.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
  21. #21
    2000 VS Ute 5 Speed
    Oct 2008
    Western NSW
    I have the exact same problem with my VS ute mate, plenty of chugging, i smell fuel and i can hear the pump making a strange moaning sound when i turn on my acessories, it is meant to make a little buzz for 2 seconds but mine literally moans, and it does'nt sound good at all. I have a brand new genuine fuel pump ready to be installed but i have'nt had time to do it yet. I have been told that the fuel pump is the problem and once i put the new one in , everything will run normal.
  22. #22
    Aug 2009
    Yeah well now mine doesn't even start, I can't hear a thing anymore. Ill get a new pump tomorrow, now I have the new filter in and with a new pump it should be all good.
  23. #23
    Aug 2009
    This is getting more than a joke now. Today the fuel pump decides to work, like what the? So the car started and all so I left it running for about 10 then it started chugging again, could the pump be faulty? It is electrical, maybe it runs a bit then dies?
  24. #24
    Dangerous Dave is offline Donating Member
    VS Berlina
    Mar 2009
    the pump may have an issue when hot. in theory the fuel is used to cool the pump, but they can still get warm. just replace it...
  25. #25
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    There is a known problem especially with utes where they die on corners when the tank is less than 1/4 full - this is due to the fuel return hose getting either dislodged from the swirl pot or split/broken. This problem usually occurs after the pump has been replaced. Do a search and you will find plenty of examples.
    The way to double check oif this is the case is whether the car runs OK on a full tank....if it does then it indicated the problem mentioned above.
    Other things that can affect your fuel supply are the fuel pump relay and the oil pressure switch which will play up if saturated with degreaser plus the fuel filter as mentioned in my previous post.
    If it was me, I'd be doing the easy checks first before going to all the hassle of fitting a new pump only to find it was the fuel filter/relay/OPS.
    Her is one of many links:vr fuel issue.........
  1. cracking open fuel tank to change fuel pump?!
    By VS5spdV6uteowner in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-01-2009, 08:00 AM
  2. Will a fuel pump pump oil?
    By VYMAD in forum General
    Last Post: 12-11-2008, 09:07 AM
  3. Fuel pump issue, or fuel line blockage? not sure help!
    By SKNOT9 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-09-2008, 02:08 PM
  4. leaking fuel damper and fuel pump adventures
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-08-2006, 04:00 PM
  5. VS Internal fuel pump issue (duel fuel)!!!
    By futronix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2005, 08:10 PM
