Results 1 to 20 of 20
Thread: Funny Problem
    HamaTime™'s Avatar
    HamaTime™ is offline VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    Default Funny Problem
    Ok this is kinda weird, I took my airbox out of my VS V6 today to paint it, put it back on, cleaned some of my engine bay with some grime and bug removers stuff...
    Driving home this evening, the fuel guage dropped, reading that I had almost no fuel (LPG) left where I should have had a 95% full tank (as I'd filled it up the previous day and barely driven) switched over to Petrol and it read fine....
    However, when revving or accelerating it makes a sharp whistling sound, or a sharp 'sucking' sound. And it idles very roughly...but is fine when it revs.
    I have no idea whats going on here. Going to take it to the mechanic tomorrow, just wanted to know if someone has had the same problem or whether someone knows what might have happened?
    Cheers!
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    ryno_vrx's Avatar
    ryno_vrx is offline Donating Member
    VR HSV enhanced Berlina
    Nov 2008
    Mirani
    HamaTime™'s Avatar
    97 - VS S
    Feb 2008
    Funny as in I can't work out what the problem is...haha I had a couple of beers before I wrote it...kinda tired
    1997 VS II - S
    Trayner's Avatar
    Trayner is offline L337
    1996 Vs Commodore Acclaim, 1996 Vs Commodore Ute
    Aug 2008
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by HamaTime View Post
    Cheers!
    you didnt disconect the MAF or the Air temp sensor and not recconect it?
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    HamaTime™'s Avatar
    97 - VS S
    Feb 2008
    Quote Originally Posted by Trayner View Post
    does it sorta sound like you have a supercharger on. like , sucking in air ?
    Yeah bro, like a very sharp sucking in sound. Not a normal induction sound though...
    Quote Originally Posted by WogBoyz View Post
    I disconnected it, but then I swear I put it back in, it clipped in allright..but that doesn't explain why it's not reading the full tank of fuel and the rough idle?????
    1997 VS II - S
    vx s pack II
    Jan 2010
    aLKIDA
    I dont no about the LPG.
    But you said you took the air box out there could be a air leak somewere.
    When there is a air leak in the intake duct the car will idle rough. So just check if there is no leak.
    WogBoyz's Avatar
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    if the maf isnt in proprely i though it will idle rough
    Trayner's Avatar
    Aug 2008
    HamaTime™'s Avatar
    97 - VS S
    Feb 2008
    Well it's now reading the fuel which is a start...I took the airbox out and made sure everything was in properly, it idles better but still rough, can't think where else to look, the rest of the intake pipe is ok, then the LPG air mixer system is tapped onto the pipe so unless there is a problem in that.
    Bottom line is, it's still idleing slightly rough.
    1997 VS II - S
    1993 V.R under construction
    Feb 2010
    Default VR v6 fuel
    Hay again
    Just looking for a diagram for fuel system for this commodore and more so the return side of it thanks
    HamaTime™'s Avatar
    97 - VS S
    Feb 2008
    what does your fuel diagram have to do with the subject of this thread? search to see if the topic has been covered before, if not post a new thread.
    1997 VS II - S
    fkford is offline Love The Beast!
    VS exec S2
    Mar 2009
    double check your AFM but if it keeps doing it have a look at the hose that go's from the gas converter (i think) that travels downways towards the floor.. last time this happened to me on gas the hose at a split in it..easy fix
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Is the air temp sensor on the airbox connected?
    Visit my Facebook page
  15. #15
    Subaru Forester GT, ET Turbo Pulsar, VS 5.0L Ute
    Oct 2009
    Frankston, Victoria
    Hey mate, you MAY have a gas leak somwhere, i know when my car has **** all gas left it sounds exactly like you described, so that could explain the gauge reading wrong, does it make the sound on petrol too?
  16. #16
    HamaTime™'s Avatar
    97 - VS S
    Feb 2008
    Thanks for all your reply's guys. I ended up fixing the problem.
    There is a small plastic hose (encased in rubber) that runs from the bottom of the throttle body, under the plenum and through the heads to a set of two plugs at the back left of the engine near the Trans Lock. The hose had been blown off when it backfire when the Air Temp Sensor wasn't connected properly.
    So if anyone encounters this problem in the future. Check that hose
    1997 VS II - S
  17. #17
    VS exec S2
    Mar 2009
    ohh thats common.. i wrapped duck tape around the bit that you connect the hose onto so its a tighter fit... was happening to mine heaps to.
    must be an LPG thing i suppose?
  18. #18
    HamaTime™'s Avatar
    97 - VS S
    Feb 2008
    Quote Originally Posted by fkford View Post
    haha good form, I thought about that, but my mechanic told me to super glue it...so i superglued that sonofabitch good!
    Took me nearly an hour to get it perfect though....it is barely long enough to reach both ends!
    1997 VS II - S
  19. #19
    vr94ss's Avatar
    vr94ss is offline walks barefoot
    VR SS '94
    Feb 2009
    Lismore, NSW
    Never heard of hose clamps?
  20. #20
    HamaTime™'s Avatar
    97 - VS S
    Feb 2008
    no seriously mate you don't understand how insufficiently short the pipe was. I'd stick it in half a cm one side and it would pop out the other side. I have no idea why it was that short. Super Glue is no problem, just cut the pipe and slip another hose rubber on the connectors.
    1997 VS II - S
  1. funny pix...
    By rattattack1313 in forum Jokes/Humour
    Last Post: 15-04-2007, 12:14 AM
  2. funny
    By myvq5ltr in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-12-2006, 05:30 PM
  3. A funny
    By Lish in forum Jokes/Humour
    Last Post: 24-01-2006, 11:36 AM
  4. Funny?
    By wes_v8 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-11-2005, 08:55 PM
Tags for this Thread
