Results 1 to 21 of 21
Thread: how wide are ur tyres on ur vr/s ??
    VS 5L UTE - VR V6 5SPD
    Oct 2008
    bayswater
    Default how wide are ur tyres on ur vr/s ??
    put sum vx gts wheels on my vr and the the tyre sidewall is hard up against the shock
    tyres are kumho u31 245/35/19
    im running 235/35/19 on my vs ute with no problems at all but with dirty dog rims.
    any 1 had any problems with 245's on front of vr??
    Mar 2009
    you can adjust your camber slightly so it clears the front shock, then it will be fine. Ive ran 245's on the front of vr and vs for a long time with no problems.
    Oct 2008
    bayswater
    is it rubbing cause of the offset of the vx gts rims?? there genuine rims too, tyres need replacing soon anyway, thinking i should just get sum 235's for the front and 245's for rear, that should fix the problem yer??
    Mar 2009
    offset should be fine i think, you can run 245's you just need to adjust the front camber, get a wheel alignment done when you get new tyres and all will be sweet.
    Vr Executive s2
    Jan 2010
    Default tyre size on vr
    i got 245/45/17's on my vr had no wheel aligment done on it as it had one a week before i put my tyres on it and it cleared no problem kinda odd
    and please dont nock my bad spelling
    Oct 2008
    bayswater
    yer i dont want to mess with the camber yer i dunno wat the deal with my car and this combo is....
    Vr Executive s2
    Jan 2010
    Oct 2008
    bayswater
    N/A
    Nov 2009
    If they are original 19" wheels they will be a +48 offset. Generally aftermarket wheels are a +45 offset. I know it's only 3mm...but its 3mm further away from the shock. Check your load rating on your tyre placard, if the minimum load rating is <=91 then you should switch to 235/35R19's all round.
    www.thewheeldeal.com.au
    Ask me for a great deal on tyres & wheels shipped Australia wide.
    VS SS commodore
    Aug 2009
    scarborough
    My VS SS has VE SSV wheels on it 245/35/19 with lovels eliminator suspension and super low springs all round.
    wheels don't scrub out or rub on anything even with a full car load
    Daily : 1996 Series 2 VS SS commodore
    Drift Pig : Nissan Silvia S13
    Mar 2009
    Quote Originally Posted by rob_rob View Post
    you will probably find your camber is out and needs adjusting so it doesnt wear out the inner edges. A wheel alignment will tell you if thats the case.
    bloodyricho's Avatar
    bloodyricho is offline Bloody Richo
    Vr V6 Equipe (hare) and VE SV6 (tortise)
    Dec 2009
    littleton nsw
    Red face another memcal eprom question
    think we could make this work on a VR all the BMW snobs do it to theirs. just need to know where the OE etc is on the commo eprom compared to the BMW's then we can all haqve two tunes easy and cheap as
    Making and running DUAL CHIPPED ECU SINCE 2010
    Mar 2009
    Quote Originally Posted by bloodyricho View Post
    Whats this gotta do with " how wide are ur tyres on ur vr/s ??"
    HamaTime™'s Avatar
    HamaTime™ is offline VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    Usually run 245's on the back, 235's on rear. But going to run 235's all around on my next tyre change (getting Nankang NS2 18")
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
  15. #15
    Holden VS Series II 1997 Ute - 5 Speed Manual
    Aug 2008
    Ive got 17's here with 235/45 all round which makes sense for ease of swapping tyres around for different wear patterns, they also have the rim saving lip which would almost be the equivalent of 245's and it clears the front strut by like 2mm and it will occasionally scrub on the back with a load whilst going to quick around corners
  16. #16
    vs ss
    Aug 2009
    reservoir
  17. #17
    Aug 2008
    Quote Originally Posted by lebowarrioz View Post
    ive got 19 on minee and running 265 on rear it looks toughhhhhhhh
    Wheel Spacers much? Or massive scrubbage?
  18. #18
    VS BT1 5LTR ex police commisioners car
    Oct 2009
    GERO WA
    vs ss
    Aug 2009
    reservoir
    never scrubeed ever no wheel spaces ive got that thingy that adjusts the camber im sitting on a massive camber so i dont really know why it doesn't scrub ill send pics to prove it if u like
  20. #20
    Oct 2009
    GERO WA
    Aug 2008
    Ah no probs you got IRS, its a bit more believable now.
    Quote Originally Posted by VS304exec View Post
    is camber bad? cuz my back wheels are like fully tilted
    Yes rear camber is bad and will cause terrible tyre wear, id recommend getting a 4 point camber kit whilst you still have usable tread left on your rear tyres.
  1. Will 185 Wide Tyres Fit On 6 Inch Wide?
    By sweefu in forum General
    Last Post: 12-01-2010, 10:09 PM
  2. wide tyres
    By VKCOMMO in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-08-2009, 08:37 PM
  3. wide body kit
    By curry in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-12-2008, 10:31 PM
  4. wheels.. how big / how wide?
    By 666vt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-11-2008, 09:39 PM
  5. Wide Wheels on VT
    By shomesta in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-12-2005, 11:20 PM
