Results 1 to 6 of 6
Thread: VX/VY/VZ Clubsport brakes on VS
    VS SS commodore
    Aug 2009
    scarborough
    Default VX/VY/VZ Clubsport brakes on VS
    G'day all ,
    i was wondering if anyone has looked into or has done this sort of upgrade?, putting VX/VY or VZ clubby brakes on there vs...
    as my SS really doesn't want to stop, the brakes are useless and are even worse with the new 19 inch wheels i put on acouple of weeks ago.
    if someone has i would like to know, how much did you pay for the brakes ? (ether from wrecker, or shop ) did you have to modify anything to fit them on ? . how long did it take you or the person who installed them ?.
    you input would be much appreciated
    Daily : 1996 Series 2 VS SS commodore
    Drift Pig : Nissan Silvia S13
    VZ AWD One Tonner
    Jul 2006
    Hi mate,
    Unless you're talking about the Harrop's or AP, late model HSV only ran the std Commodore caliper, or the C5 Corvette caliper (most Clubsports were just the C5 caliper), neither of which would be better than a VE conversion. The VE also has smaller pistons which means you don't need to change your master cylinder. 322mm rotors on twin pot VE calipers with decent pads will be MORE than enough:
    VE Twin Piston Upgrade Package suit VB-VZ Commodore!!!
    Regards,
    Greg
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
    HamaTime™'s Avatar
    HamaTime™ is offline VIP Member
    97 - VS S
    Operation Tiger Champion! Marble Mayhem Champion! Spacerunner 2 Champion! Triathlon Champion!
    Feb 2008
    With the VE brake upgrade having smaller pistons, do you need to change the brake booster as well? Or is it basically just new calipers and new rotors?
    1997 VS II - S
    Stage II Auto: Pacemakers & 2.25 Hi Flo: VT Brakes: Lowered: Spaced & Insulated
    VZ AWD One Tonner
    Jul 2006
    Sorry, I meant smaller pistons than VT or C5 calipers. The VE piston volume works well with std VS booster/master.
    HamaTime™'s Avatar
    97 - VS S
    Feb 2008
    Quote Originally Posted by gslrallysport View Post
    This may seem like a retarded question, but even with smaller pistons, does that make the VE brakes alot more responsive and alot quicker braking than a VT brake upgrade?
    1997 VS II - S
    VZ AWD One Tonner
    Jul 2006
    Quote Originally Posted by HamaTime View Post
    Spot On!!!
  1. [SA] VX Clubsport Bodykit & VR Clubsport Bodykit - Complete Kits
    By OnionbulbR8 in forum Parts And Other Items For Sale
    Last Post: 30-03-2010, 07:36 PM
  2. VZ Clubsport brakes???
    By Commydoor in forum General Discussion
    Last Post: 05-12-2009, 07:14 PM
  3. VE Clubsport Performance Brakes
    By dr_brakes in forum VE Holden Commodore (2006 - ?)
    Last Post: 25-02-2009, 03:24 PM
  4. Drum brakes to Disc brakes conversion
    By sheepz89 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-09-2008, 09:34 AM
  5. ABS Brakes
    By Spyder in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-09-2005, 04:19 PM
