hey all vs commodore , i seem to experience a grinding noise comming from what appears to be the rear right tyre or could be the diff im not sure happens when i excelerate slowly then it goes away could this be a wheel bearing or no because its not a constant noise ?
could be your pads on rotors (metal to metal) will make that nice grind sound.
dont worry, il start a ride thread soon.
but its when im excelerating not braking ?? is that still possible ?
it can still make that grinding noise when rolling at slow speed.
Does the diff make a whining sound?
May also be the diff.
When was the last time you changed the oil in there ?
Cheap solution....give it some freash oil and see what happnes.
