Results 1 to 6 of 6
Thread: replace clutch cable vs v8
    vs ute
    Mar 2007
    Question replace clutch cable vs v8
    i have just brought a new clutch cable, when i dropped the plastic cover under ths colum
    it looks like a nightmare to get your hands in the to undo the clutch pedal-etc.
    all plastic aircond ducting doesnt seem to want to pull apart?
    cant see how you could get a spanner on the clutch pedal bolt?
    Is there a trick/ easy way to perform this job? (VS V8 T5 1997)
    bottleinspector is offline power starved westy
    vs bt1
    Jan 2010
    liverpool, nsw
    you dont need to undo anything, just move the clutch pedal around til you unhook the end, do the same with the box end and then reverse the procedure
    vs ute
    Mar 2007
    i need more room, i have tryed going in with the fuse box cover trim down not enough room for my hands which are fairly small.
    cant go up from the pedals as theres a cover that needs to be removed?
    i can barely see the cable with a torch,let alone get my hand in there.
    sounds like a streight forward job when you read the repair manual? (max ellerys)
    i must be doing something wrong
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    It is a nightmare without removing anything. Remove the air duct next to the clutch pedal (one phillips head screw) then undo the clutch pedal bolt (13, 14, 15mm?) and remove the clutch pedal. By far the easiest way. Just remember the orientation of the pedal spring prior to removal.
    AFAIK VN-VS is the same.
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    vs ute
    Mar 2007
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Oh yeah, and if it wasnt already obvious you need to remove that black plastic cover (series of screw type clips) and the metal bracket securing the fuse panel (3-5 phillips head screws).
    Overall not that difficult. Just time consuming.
    My (ex)Ride
  1. How To: replace accelerater cable VN/VP/VR
    By The Darkness in forum Holden Commodore How-To's
    Last Post: 23-12-2011, 09:05 PM
  2. vs clutch cable
    By VSEXEC in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-06-2009, 07:15 PM
  3. How do i replace the handbreak cable?
    By <atomicL93> in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-05-2009, 10:20 PM
  4. replace accelerator cable
    By Goon in forum VL Holden Commodore (1986 - 1988)
    Last Post: 09-05-2009, 07:46 PM
  5. replace accelerator cable
    By The Darkness in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2007, 02:13 PM
