Results 1 to 8 of 8
Thread: VS Not starting
    VR Ute
    Dec 2009
    Default VS Not starting
    My VS has progressivlly gotten worse over the last dew weeks at not starting. If you put the key in and go to start all the accessories etc come up but when you go to start there is nothing. the radio and lights go back out and there is no noise from the starter motor or anything. I know this is a common issue when terminals arnt on correctly but if you take the key out and try it again it will go. Its been getting worse in that you have to take the key out and put it back in and try again a number of times now before it will start.
    Has anyone had this issue and know how to fix it ?
    '97 VS Commodore + '98 E36
    Apr 2005
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    At a guess I'd say the ignition switch (behind the ignition key) is faulty. Another guess is that the inhibiter switch is out of adjustment - check by trying to start in Neutral instead of Park.
    My third guess is the key reader is playing up in some way - check by pressing the unlock button whilst the ignition light are on the turn further to start.
    Final thought - the keyhead has a brass nipple that must make contact with the chome ring around the ignition keyhole when you insert the key - make sure it contacts this ring as it unlocks the immobiliser.
    Kurtp's Avatar
    Kurtp is offline VR Buicks > You ;)
    VR Series 2 V6 Sedan
    Aug 2009
    Pakkey VIC
    Quote Originally Posted by hako View Post
    One of hako's ideas will be it for sure, check your error codes, it will tell you right away if there is any logged immobiliser issues (suggesting its the keyhead) Though first try starting it in N instead (when you do this make sure you havn't just unlocked the doors, as i believe the central locking turns off the immobiliser for a short time)
    vs senator 5.7
    Oct 2009
    melbourne s.e
    vs ss
    Feb 2010
    Default vs ss turns over but wont fire up
    my 5L started off back firing and miss firing then it would stall every now and then and i replaced the ignition module and it still wont start up just turns over
    vx s pack II
    Jan 2010
    aLKIDA
    Quote Originally Posted by pirelli03 View Post
    Check for fault codes.
    Check for spark.
    If you have a strong spark then you can rule out the Ignition side of the things.
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    if you have no luck with all that was mentioned try replacing your key reader, (this will work for all vr - vz commodores v6 or v8 ) the key readers wear a grove in them and no longer reads the key.
    also does your security light flash when you try and start it if so it will be the key reader. (also unlocking the car should stop the immobliser with the remote)
  1. Car not Starting??
    By Paul_grima in forum General
    Last Post: 15-01-2010, 10:22 PM
  2. Vp not starting
    By LTHL-VP in forum General Discussion
    Last Post: 04-08-2009, 12:10 AM
  3. car not starting
    By panda88 in forum Car Audio
    Last Post: 29-05-2008, 03:10 PM
  4. Still not starting
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2007, 12:14 PM
  5. Not Starting
    By Dezza in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-01-2006, 01:41 AM
