Results 1 to 19 of 19
Thread: vs running bad
    vs acclaim
    Feb 2010
    gippsland vic
    Default vs running bad
    hi all
    i recently got a vs, all was good for a week but now it is running realy rough under mild acceleration. idles fine, runs ok when accelerater pushed to floor (not flogging it), but taking it easy around town and sitting on high way at 110 it breaks up bad. (feels like my old kingswood did when it fueled up) i pulled out a plug and it was clean and in goood condition. goingt o try a code check today but dont want to start throwing dollars at it to fix it untill i have a better idea where to throw it properly.
    thx all
    macka
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    It sounds like a bad plug or lead, probably lead.
    MY RIDE
    vs acclaim
    Feb 2010
    gippsland vic
    fingers crossed thats all it is. havnt been out to it today, too hot to play today. lol
    thanks for ur reply its got me less stressed now.
    oh on another note, this is my first vr/vs commodore, last was a vq caprice and i now want to join the " I HATE VS IGNITION BARRELS" club
    vs acclaim
    Feb 2010
    gippsland vic
    lazy bug bit me hard today. thanks for the reply.
    i will get out and check it soon now its a bit cooler weather. also will check to see if it gives me a error diagnosis.
    vs acclaim
    Feb 2010
    gippsland vic
    just did the test for the fault codes and got the following
    Code 47 - Crank Angle Reference Signal
    can someone plz tell me what this means, what needs replacing and would this cause my problems i am having.
    ty
    vx s pack II
    Jan 2010
    aLKIDA
    If you own a oscilloscope you can check the pattern on the CAS.
    To confirm the CAS is faulty.
    But if you dont have one just change the CAS sensor
    vs senator 5.7
    Oct 2009
    melbourne s.e
    vs acclaim
    Feb 2010
    gippsland vic
    thats ok, did one on a vn v6 so know what im in for. is that the answer to my car running so rough or should i still put new leads/ plugs on. dont want to spend money i dont have to if possible.
    thanks for the replies all.
    great forum..
    Mar 2009
    CAS should be enough to get it going again, but a new set of leads and plugs never hurt
    Lean Backk is offline Banned
    mad
    Feb 2010
    vs acclaim
    Feb 2010
    gippsland vic
    thanks again. will get a CAS next couple days and try it. plugs were in good condition and leads seemed ok (ends looked good they were not stiff and dont look to old). be happy to get this car running right again.
    vs commodore wagon
    Mar 2010
    Default vs running like pig
    HI ihave a vs commodore its running rough at an idle and when driving. i have changed the plugs and leads changed the fuel filter and checked the coil packs. And now i'm stumped. Please help thanks
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by vskurt View Post
    Hi, go back to the main VR/VS page and click on New Thread near the top left of the page to start your own thread.You will get you more answers and better help this way,this thread is about someone elses problems.Cheers.
    vs acclaim
    Feb 2010
    gippsland vic
    i changed the CAS and running like a dream now. $70 from bursons and a hour to fit it ( took 20 mins to find my harm bal puller) thanks for the advice all.
  15. #15
    vs acclaim
    Feb 2010
    gippsland vic
    seems to be starting to behave like it was before i replaced CAS. only been in a week and was running great till todays drive. exact same symptoms as before. i will try a error code check tomorrow.
    could the CAS be stuffed already? this seems unlikely.
  16. #16
    VSIII s-pak ute 3.8l 5-speed
    Feb 2010
    it appears that the non-genuine CAS's are great at lasting 1-2 weeks and then dying...
    Get a genuine holden one and you shouldnt have any problems.
  17. #17
    vs commodore
    Oct 2009
    Tamworth NSW
    I have seen brand new aftermarket CAS's fail from new.Stick to genuine holden sensors,they cost a bit more but they work out cheaper in the long run.
  18. #18
    Vsfan95's Avatar
    Vsfan95 is offline Vsfan95
    VT Series 2 Acclaim
    Dec 2009
    i had the same problem with my VS I found it was my harmonic balancer and my CAS
  19. #19
    vs acclaim
    Feb 2010
    gippsland vic
    what do u think of my chances of bursons giving a refund for the faulty one. was only in car for 1 week..
    only milk and juice should come in 2 litres
  1. 253 Running hot
    By Nackerz in forum General Discussion
    Last Post: 15-12-2009, 06:55 AM
  2. running in help
    By HSV.421 in forum V8 Development and Modification
    Last Post: 09-12-2009, 10:31 AM
  3. VS Running hot
    By cypher967 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-10-2009, 06:58 AM
  4. Vr Ute - not running right
    By linz87 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-07-2009, 02:45 PM
  5. VR Engine light stays on running running alittle rough
    By AJKoo1 in forum General Discussion
    Last Post: 07-09-2006, 01:08 AM
