Results 1 to 19 of 19
Thread: Air Conditioning Belt too small on a 5 Litre
    VT SS 5.7L Commodore.
    Feb 2004
    NSW, Australia
    Default Air Conditioning Belt too small on a 5 Litre
    Hi All,
    I have a 5 Litre VS Ute, I bought a new air conditioning belt for it, well I have since then bought another two.
    They are all too small for it. I don't understand how? I got one from a auto spares place over the counter, the other two from Supercheap, So surely all using the correct part numbers.
    I have the tension pulley adjusted fully loose and for the life of me I can not get the new belts on.
    Has anyone come across this problem before?
    Thanks,
    Jim
    Yours Kindly,
    Jim
    VS II 5 ltr Berlina Wagon
    Apr 2004
    Yes, sought of. I changed my belt over a month or so ago myself for the 1st time and they are very, very tight to fit. I thought the same thing i.e. they should be at least 5 to 10 mm longer, but after huge amounts of perseverance and using a screw driver to lever the belt on I did it. I just can't recall if I took the tensioner pulley off completely before I put the belt on or not ????
    Mmmmm V8
    vs senator 5.7
    Oct 2009
    melbourne s.e
    if your old ontensioner pulley off completely before I put the belt on or not ???? it helps alo
    Feb 2004
    NSW, Australia
    The belts I have are about 10mm off. I might have to try again with a screw driver. I just thought this can't be right. I have tried with the tensioner pulley off.
    Yours Kindly,
    Jim
    Mar 2009
    ParkwayDrv's Avatar
    ParkwayDrv is offline ɹoʇɐɹǝpoɯ ǝsınɹɔ ɐʍ
    VZ SSZ
    Feb 2009
    we did the one on my mates car the other day, they are a ridiculous tight fit
    Black, Red leather, 20" Pentagons, Red walls, Lowered, OTR, Mafless, 3.9s, Diff dumpers, 341rwhp...
    185i, Chasers, Flappers, Venetians, Sunvisor, Twin diff dumpers, 194rwhp...
    Apr 2004
    Quote Originally Posted by westbad View Post
    did you put it around the crank 1st?
    Good thinking. It's better to start on the crank 1st and then persuade the belt with a screw driver to fit over the compressor pulley. I recall it took me a few attempts as the belt can twist over as it goes onto the compressor pulley.
    Mmmmm V8
    Disturbed_vegeta's Avatar
    Disturbed_vegeta is offline I'd Prefer To ROAR!
    Vs Statesman, Vr Senator 185I
    Dec 2005
    Burpengary
    i did it to mine the other day, took all about 15mins but i have a hoist to make it easier. But yeah, very tight
    vs ute
    Dec 2008
    Hi Guys
    I had same issues some time ago and got the answer from this site.
    From memory, the power steering unit is the tention adjuster.You need to loosen the top and bottom bolts of the pwr steer pump and it will slide allowing easy fitment of belt.Then just lever the pump back and tighten the bolts
    Apr 2004
    Hi VS Ute III, the 5 Litre A/C belt is a belt on its own. Sounds like you are describing a V6 serpintine belt arrangement ???
    Mmmmm V8
    VR Caprice
    Dec 2005
    No He's got it right. The Bracket behind the Power Steering pump is the A/C condensor bracket. There are bolts on this bracket if you loosen you can get about 5 to 10 mil as the bolts are cut on a slide. Then get a bar and bar this bracket back, nearly a 2 person job.
    Apr 2004
    Yikes, sounds ugly. I'd keep perservering with the old screw driver !
    Mmmmm V8
    Feb 2004
    NSW, Australia
    Yeah I have loosened the power steering pump, no go. I still can't get the belt on. Tried different brands of belts and from different stores.
    Yours Kindly,
    Jim
    Mar 2009
    they are a pig to get on, last one i did kept twisting when i was fitting it, got there in the end tho.
  15. #15
    VR Caprice
    Dec 2005
    Patience is needed. Put the belt in Hot water for 5 mins before to make it more supple.
  16. #16
    VS statesman S3
    Apr 2008
    Had same problem with VS series statesman V8.
    Tried Bosch A/C belt spec 13A0840 just would not fit.
    Tried Dayco A/C belt spec 13A0850 was able to fit.
    The Dayco is 10cm longer than the Bosch belt, both belts were specs
    from the companies catalogs for my model car.
  17. #17
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    i just done 2 on the same car. just wind the crank over whilst threading the belt on. the a/c compressor locked up and threw the belt thats why i did 2
    edit: genuwine holden belt with correct part no. for that vehicle
  18. #18
    Feb 2004
    NSW, Australia
    Thanks guys, I managed to find a belt to fit. Bosch 13A08650 I think was the part number. It was 25mm bigger then the 840 belt.
    Yours Kindly,
    Jim
  19. #19
    Apr 2004
    Congratulations and enjoy some cool air before autumn sets in !
    Mmmmm V8
  1. Naturally aspirated V6 accessories belt versus L67 supercharger belt
    By VSSECO in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-11-2009, 09:23 AM
  2. air conditioning belt
    By darin in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-10-2008, 02:08 PM
  3. VR V8 Air Conditioning Belt.
    By Onecontrolfreak in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-02-2007, 06:54 AM
  4. VR V8 Statesman Air Conditioning Belt
    Last Post: 12-01-2007, 09:38 PM
  5. CRS Supercharger small pulley belt
    By commodore in forum V6 Development And Modification
    Last Post: 27-01-2006, 09:41 AM
