Results 1 to 8 of 8
Thread: !!!battery light on out of no where??
    vr executive
    Nov 2008
    Default !!!battery light on out of no where??
    hey guys
    i was driving my vr v6 tonite
    and out of no where the battery light came on and my dash lights brightened right up and the car started making a whisling sound..
    any ideas?
    cheers
    JD
    JD is offline Donating Member
    VS Berlina
    Aug 2006
    Deep South, SA
    vr executive
    Nov 2008
    vx s pack II
    Jan 2010
    aLKIDA
    With the car running at idle check the voltage with a multimeter it should read between 13-14 volts.
    If its under then the alternator is no good. If the alternator is over charging say like 15-16 volts
    Turn the car off straight away if it keeps running at this voltage it can damage the PCM and other electrical components because of the higher voltage and chnge the alternator there cheap and easy to fit.
    vr series 2 v6
    Oct 2009
    nsw
    i have this problem as well, i just wriggle the top plug an the revs die down and it fixes itself? ive changed alternators and everything, any ideas?
    Vs eco 3.8, extractors, 2.75" exhaust, roller rockers, cammed, bored out 20, t5 manual, rolling on king springs all way round with monroe gt shocks all way round, every door has a ding but looks can be very deceaving
    vx s pack II
    Jan 2010
    aLKIDA
    Was it a brand new alternator?
    And what plug do you wiggle?
    The Regulator could be stuffed up.
    The Regs job is to stop the voltage going to high. And regulates the voltage to expectable level 13-14
    vr series 2 v6
    Oct 2009
    nsw
    you got two lots of wires, your red one that bolts onto the back of the alternator, and one that has a plug that goes on the top of the alternator, the one with the plug on it, ive evan tried changin the black box over from alternator to alternator, so im stuped, and the vr has a little box earthed out and plugged into the back of the alternator as well, i changed that over as the s1 vn alt i had to use does not have 1
    vx s pack II
    Jan 2010
    aLKIDA
    Well maybe the pins on the plug are not making contact properly or are dirty.
    The black box is the regulator. Make sure the plug and regulator are making good contact when plugged in.
  1. battery light
    By muney in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-05-2010, 11:55 PM
  2. battery light with brand new battery
    By andyli in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-03-2010, 09:48 AM
  3. Engine stops, fuel light on, battery light on GOODBYE
    By scarletx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 03:43 PM
  4. Battery light & Check Engine light
    By Sledge in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-09-2008, 06:30 PM
  5. battery light on & orange light on
    By smokey.29 in forum Electrical Wiring / Questions
    Last Post: 12-02-2007, 06:16 PM
