I can get a VX L67 motor with loom will the it go into my car no hassle my car is a 95 VS Lexcen with live axle would i have to change the diff and gear box plus can u blot a Manual gear box up to the L67 wouldn't mind VS L67 5 Speed Manual it would be mint
Motor will bolt in fine, but your best to get a VS L67 PCM and loom, the L67 auto is strengthened but your standard one will work fine if in good order. no need to change diff.
They where never released as a manual but there is nothing stopping you bolting a T5 or Getrag onto it, plenty of people have already done it, although you will need a custom tune if planning manual.
Power is measured in DECIBEL
SWEET cause i was going to do a LS1 conversion but i had a look around here and other forums and easy 10k plus and i can get a L67 for $500 to $1000 and $300 labor to fit so ill do that would be cool to go LS1 in a VS but to dear i could work the L67 and still be less than 10K. So VS L67 PCM and loom and it will bolt up to my standed auto cool might leave it auto just get a shift kit
the temp sensors are different on the vx motor
Ok temp sensor diff so can it be changed or no just get a VS L67
it can be changed no big deal
So just get the VS L67 PCM and loom and temp sensor then i can go ahead and put the VX L67 in sweet
