Results 1 to 11 of 11
Thread: Vs v6 manual flywheel bolts
    vscom88's Avatar
    vscom88 is offline Andrew-
    VS 5speed
    Dec 2008
    Default Vs v6 manual flywheel bolts
    Hi, Does any1 know how tight the flywheel bolts should be done up on a manual Commodore vs v6. im after the exact specifications if any1 knows it..
    cheers
    vs series II berlina
    Sep 2005
    vscom88's Avatar
    VS 5speed
    Dec 2008
    i had alot of vibration in my car, the flywheel bolts were loose. i would not be putting lock tight on flywheel bolts ever. if the bolts snap ur screwd .. im after specs in CI or NM so if you know it please share ..
    vs commodore
    Oct 2009
    Tamworth NSW
    In the Gregorys manual its got first stage= 18 - 22 NM.Then for the second stage another 47-53 degrees,(just past an eighth of a turn),or for series 2 manual an extra 80-90 degrees,(a quarter of a turn)
    vscom88's Avatar
    VS 5speed
    Dec 2008
    azzfox's Avatar
    azzfox is offline slideways
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    If I recall the above specs is for the 8 bolt setup. The 6 bolt setup uses larger bolts and are done up much tighter. The 8 bolt setup you have to be careful because the bolts do stretch and snap fairly easily. The 6 bolt on the other hand Im pretty sure you can use a rattle gun though I would still use a torque wrench lol
    EDIT: Im a retard. This isnt the VN/P section . Also missed the title... dont ask.
    My (ex)Ride
    Quote Originally Posted by ari666 View Post
    LMAO!!! bracelets!!! and neck chains?!?!? they are as gay as aids.
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Nice 4 year old thread dig dude....got a permit to mine that deep?
    vscom88's Avatar
    VS 5speed
    Dec 2008
    ah alright thanks.. yes i have an 8 bolt setup and they're pretty small .. and for things like head bolts, flywheel bolts and major components like that i always like to do them up to manufactures specifications if you know what i mean ..
    but cheers anyways guys
    Cammed mafless VS Calais 5-speed.
    Dec 2008
    2004 XR6T & 1990 VN dragcar project
    Jan 2010
    Bendigo, Victoria
    ^^^ I've gotten snapped off lock-tighted flywheel bolts out before.
    You don't have to use 'extreme' loctite, just use blue (medium) or similar
    vscom88's Avatar
    VS 5speed
    Dec 2008
    flywheel bolts have a certain torque setting for them. like i said id never use loctight on flywheel bolts. and why the hell would u use new bolts everytime? unless a bolt is screwd its fine. plus i put the flywheel back on to the according NM so yeaa..
    this thread may as well be closed
    thanks for your help fellas
    azzfox's Avatar
    VN SV3800 #012, N13
    Sep 2005
    Yarra Valley, VIC
    Quote Originally Posted by vscom88 View Post
    Because they are subjected to alot of heat and stress therefore become fatigued. Rule of the thumb is always use new bolts. I dont know about you but I dont want my feet being taken off by a flywheel. Yes they are capable of this. Think about it, a fair few kilos of mass (plus clutch) spinning at multiple thousand rpm. Just think of what the bolts go through on a hard launch! I would be making sure that thing is clamped down hard and secure. So in saying that I would also advise new bolts with a medium strength thread locker.
    But thats just me.
    My (ex)Ride
  1. VK Flywheel bolts
    By VK SL 3800 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-06-2010, 06:17 PM
  2. torq settings for flywheel bolts
    By hrtmad in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-09-2009, 08:49 AM
  3. Broken flywheel bolts ??
    By Michelson4301 in forum V6 Development And Modification
    Last Post: 02-03-2009, 12:10 PM
  4. flywheel bolts
    By crossy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-10-2007, 06:05 PM
  5. torque setting for flywheel bolts
    By baz1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-10-2006, 03:52 PM
Tags for this Thread
