Results 1 to 17 of 17
Thread: Harmonic Balancer?
    vs commodore
    Feb 2009
    Exclamation Harmonic Balancer?
    hey guys, the harmonic balancer carked itsef today so me and my mate are fgonna fix it after work.
    i just have one quick question tho. i no how to take the bolt off.. i have a rattle gun and a really good compressor aswell.. just wondering if you need a pully puller?
    also is there any gaskets or anything like that rthat id need to change?
    thanks again
    jamie
    vs commodore
    Oct 2009
    Tamworth NSW
    you will need a puller and 3 suitable length, (about 2-3 inches long), 1/4 UNF bolts.These bolts screw into the holes around the balancer to connect the puller.
    vs commodore
    Feb 2009
    thanks mate, do you know how much they are?
    and also is there any gaskets or anything that has to be replaced?
    Mar 2009
    you can normally get them off by hand if you wobble it from side to side and pull it will come off, much like how you get a steering wheel off.
    vs commodore
    Feb 2009
    sweet, well ill try by hand first
    also one more question.. when you put the new one back on, do you have to have it at a certain tension?
    if so.. hwo do you do that?
    sorry my mates an apprentaice mechanic and i dont know a whole lot
    vs commodore
    Oct 2009
    Tamworth NSW
    The Gregorys manual says the V6 engine crankshaft pulley bolt tightens from 270-325 Nm.You will need a tension or torque wrench to get it tightened to the right specs.
    VS Exec
    Jan 2007
    Adelaide (South)
    Having just taken a couple off this saturday, I can tell you that you will most probably need a pulley remover. The one on my mates car needed the pulley remover to get it off, wasn't going to budge by hand. One car at the wrecker the balancer came off by hand, and another needed the pulley remover.
    There is a shaft seal behind the balancer (its blue), might pay to replace it, might not. And yeah, to get it done up to 300 odd Nm might need to take it to a mechanic, most torque wrenches you would find in the back shed will only go upto about 200Nm if you're lucky. Another mate borrowed one from work, goes upto 1000Nm, and its like 2m long
    vs commodore
    Feb 2009
    thanks yeh i might have to.. also one last question.. this might sound stupid. but as i said before im not much of a handy man of any sort... just wondering, my friend has a rattle gun and he said it has a maximum torque of 310nm... doe that me we can just use that instead of a tension wrench..
    sorry again if that sounds stupid.. but i havent been able to speak to my friend much today
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    just do it up super mofo tight it will be fine. i did mine up with a ratchet and a very heavy hammer without even holding the crank. shes done over 1000km of driving and hard driving on boost at that and hasnt gone anywhere and its the loose fitting vn balancer that doesnt need a puller to pull it off the crank. vp onwards should be a real snug fit will need the puller
    vs commodore
    Feb 2009
    damn i was hopeing i wouldent have to buy the puller
    ahhwell i guess i have to now, but yeh il just do what you said and bolt it on real tight.. i have the rattle gun so a quick snap of that and it should be all good
    and yeah if you car has lasted 1000kms of hard driving on boost, im sure it will hold then, it on gas and i barely ever thrash it
    thank you everyone for your help, ill let use know how it goes
    vs commodore
    Feb 2009
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Check this link: Harmonic balancer
    Make sure you get the correct harmonic balancer for your car - VS1 is different to VS2. Double check the CAS hasn't been impacted by the HB as well. Good Luck.
    в∞ѕтεכ √&
    Jul 2008
    NZ
    2nd puller is the one you want but you will need to buy the right size bolts they never come with the right ones for the commodore
  15. #15
    TheForgotten's Avatar
    TheForgotten is offline only human......
    VR EXEC
    Dec 2005
    quarantine
    Quote Originally Posted by moff_man View Post
    first one no seccond one yes
    first one will work, that's what i use, never had an issue
    but you want one bigger than 4inch (mine's 6)
    Quote Originally Posted by MY-42-VT
    if they didn't have that thing between there legs we'd laugh and throw rocks at them
    WTB VR/VS FACTORY HEADUNIT BRACKETS PM ME
  16. #16
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by TheForgotten View Post
    Thats the wrong type for the commodores,the harmonic balancers are two piece,with outer and inner rings and rubber in between.If you pull on the outer piece it usually stuffs the HB where the 2 pieces join.It probably doesnt matter if the HB is being replaced,but if you want to use it again Id be using the proper tool for the job,the second type of puller with 1/4 UNF bolts that screw into the HB.These pullers are cheap as to buy,Ive used mine heaps of times ,when I bought it I though it would be something that I would only use once.
  17. #17
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Might be an idea to replace the CAS while the balancer is off. Save on headaches later on.
  1. [SA] F.S. Harmonic Balancer 253/308/304
    By GTP 85 in forum Parts And Other Items For Sale
    Last Post: 04-11-2009, 10:13 AM
  2. harmonic balancer vn to a vr
    By Steve Ashton in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-05-2009, 08:18 PM
  3. Harmonic Balancer
    By VS-Acclaim in forum V8 Development and Modification
    Last Post: 05-01-2008, 01:45 PM
  4. Harmonic balancer
    By mikek in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-06-2006, 01:34 AM
  5. Harmonic balancer- a bit odd !!!
    By grindfiend in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-01-2006, 09:11 PM
