Results 1 to 6 of 6
Thread: fuel problems
    vr commodore
    Feb 2010
    Default fuel problems
    my vr commodore will die on a hot day for about 10 minutes unless i turn the key off and a few times then still runs sick for a little bit any ideas?
    VS V8 Berlina Wagon
    Jul 2006
    CAS is gone, when it happens again pour some water over it and see if it starts, if it does then there is your problem.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Welcome to the forum - I'd run an error code check first and see if a code 47 comes (to verify the CAS is bad). Here are the instructions: Checking error codes VR/VS (Revised)
    vs commodore 96
    Feb 2010
    Mar 2009
    Quote Originally Posted by descentia View Post
    My Vs does that too... Only on hot days. How much to fix?
    my crystal ball says $70
    vs commodore 96
    Feb 2010
    Sarcasm? I have had exactly the same problem, pouring water over it and it works again. So assuming it is just that was wondering if anyone had an approximate cost?
LinkBacks (?)
  1. fuel problems efi v8
    By Bryza in forum Electrical Wiring / Questions
    Last Post: 23-06-2009, 07:14 PM
  2. !!fuel problems!!
    By slappedvr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-04-2009, 08:44 PM
  3. Fuel problems
    By h2obro in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-11-2005, 08:39 PM
  4. fuel problems??!!!!
    By bitch in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-09-2005, 10:54 PM
  5. Fuel Problems
    By VBSL79 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-12-2003, 01:43 PM
