hey guys i was just wondering if a small leak in the plenum could be affecting idle and power. planing to fix the leak anyway. also is it worth pollishing the inside or just clean it???? thanx
A leak of what exactly?
air sorry forgot to mention that
Yeah, it'll effect idle, power, fuel economy.
As for polishing it:
There is a school of thought that shiny isn't very efficient.
Clean it, and make it smooth-ish. Hard to explain, just keep a grain in it.
yea i was under the understanding that the grain caused the air to ripple or swirl this helps it to mix with the fuel better. this is why i was asking because ive heard pple talking about pollishing.
thanx ill fix the leak and clean the insides up, and let you know how i go
No worries.
Yeah thats the way it got explained to me also
Good luck!
Does it make a wooshing sound of escaping/leaking air when accelerating? Idle slightly rough? Cold start very rough?
yea you can hear the air escaping from the plenum lid where the rubber gasket is, the idle rpm varies from 900 to 2300 almost like the tb is sticky. and yea idle a bit rough
Hmm it sounds slightly like my problem. I got escaping air coming out somewhere, idle goes down to around 4-500 and is shaking as if it is about to stall. Escaping air while accelerating as well.
Yes that's what I meant, and that's what I was under the impression of too. Although I have heard when porting heads, keeping the intake "grainy" whilst polishing the exhaust can be beneficial. I don't know anything about porting though, so I don't know if it's true or not.
Check the hose underneath the throttle body. Might have come undone? Does it backfire?
ok ill try that thanx mate. and no it doesnt back fire
