Results 1 to 6 of 6
Thread: VR to VT brake upgrade question
    VS SS
    Mar 2009
    Default VR to VT brake upgrade question
    Hi all, just a quick question, i was lucky enough to score a set of VT dba slotted rotors and calipers for my VR pretty cheap, but i was under the impression that i may need some sort of spacer/shim to do this job, is this correct? And if so where do i buy them? Thanks.
    dirt drifter's Avatar
    dirt drifter is offline white trash hillbillie
    VS 5L M5 VS 6L M6
    Apr 2009
    massive hole in the ground
    yes u need a spacer/shim thingo. its a thin metal ring that slides all the way onto your front hub and locates the vt rotor properly
    try ebay, i got mine for $50 delivered from race brakes in sydney however there are other mobs on there with them
    Quote Originally Posted by UFO View Post
    worked v8 + supercharger + dogbox = panty moistening equipment.
    4 banger turbos with bov's will just cry when they hear it, because they can never have it.
    Quote Originally Posted by GRPABT1 View Post
    Avoid cluey police
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    A shim is required between the hub and rotor. The hole in the center of the rotor and the OD of the hub are 1.5mm different. The shim is to allow the rotor to center correctly on the hub.
    VS SS
    Mar 2009
    VS SS
    Mar 2009
    VZ AWD One Tonner
    Jul 2006
    Nup, your best bet would be one of these:
    VE Twin Piston Upgrade Package suit VB-VZ Commodore!!!
    - GSL RallySport - Ph: 1300 884 836 -
    Sick of paying too much for high performance brake pads? Want high performance and cold bite with low rotor wear?
    - QFM Performance Brake Pads -
    Also specialising in
    - DMS High Performance Shock Absorbers - Monit Rally Computers -
  1. brake question for ls2 upgrade in vs clubsport
    By clubby_you in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-06-2009, 08:33 PM
  2. Another VK brake upgrade question
    By jakbob in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-04-2009, 03:36 PM
  3. Brake upgrade question
    By Troy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-10-2007, 06:47 PM
  4. brake upgrade question
    By Holdenboy_VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-10-2005, 10:17 PM
