Results 1 to 5 of 5
Thread: 1993 vr commodore fuel problem
    1993 V.R under construction
    Feb 2010
    Default 1993 vr commodore fuel problem
    Hay im having problems with my fuel pump for some reason it keeps shitting its self is there any special way of putting them in or am i just unlucky 3 in 6 weeks . The car is just a standard 6 cylinder
    Thanks
    vs commodore
    Oct 2009
    Tamworth NSW
    Hi,check the fuel pump wiring under the back of the car near the fuel tank.While the pump is running (engine running),move the wiring around and listen to see if the pump stops at all.Also check the fuel pump relay under the bonnet.(swap it for another one the same).Theres no way you would go through 3 pumps in a few weeks.Id be checking other things as well like the CAS(crank angle sensor).This can make the car stop and go and run crook like theres a fuel problem.It might be worth checking out.Also check for any logged error codes.This link shows you how to do that. Checking error codes VR/VS (Revised)
    bloodyricho's Avatar
    bloodyricho is offline Bloody Richo
    Vr V6 Equipe (hare) and VE SV6 (tortise)
    Dec 2009
    littleton nsw
    check fuel return valve too if your pumps are blowing then they are shorting or over working
    Making and running DUAL CHIPPED ECU SINCE 2010
    moff_man's Avatar
    moff_man is offline operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    Nov 2008
    also your fuel filter, if its blocked your pump will have to work extra hard...
    2004 XR6T & 1990 VN dragcar project
    Jan 2010
    Bendigo, Victoria
    otherwise, yes you can be that unlucky.
    Just check the wiring and connections, the fuses and relays, replace the filter (probably needs doing anyway). And if you still blow them........................................buy a new car!
  1. [NSW] 1993 V6 VR COMMODORE - Wollongong NSW
    By Dodgy_Dave in forum Vehicles For Sale
    Last Post: 25-07-2009, 03:30 PM
  2. FS: VR Commodore 1993
    By liquidforce_134 in forum Parts And Other Items For Sale
    Last Post: 29-06-2008, 06:20 PM
  3. 1993 Hsv Clubsport Starting Problem
    By hldngrlnz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 04-10-2007, 02:04 AM
  4. 1993 MANUAL VR Holden Commodore
    By ozute in forum Parts And Other Items For Sale
    Last Post: 18-08-2005, 04:15 AM
