Results 1 to 8 of 8
Thread: VS Ute Problem (HELP!!!)
    vs commadore Ute 1999
    Feb 2010
    Default VS Ute Problem (HELP!!!)
    Its a VS V6 Series 2 Auto
    Its Standard
    169,547 on the clock
    was in a crash about 5 months ago. got it fixed (it sat around for about 4 months, started every few days)
    1999 Model
    got it repaired, got it home found a leak in the radiator so i installed the radiator myself, everything ws working fine until the other day, i was driving down the road, car was running really well.. left the traffic lights, got to second gear (auto) then the car started to make these really random noises and started to loose power (it sounded like it was running outta fuel). i had it going for a little long then pulled over turned the car off, and popped the hood. i had alook under the hood to try and figger out what had happened. from what i could tell there was nothing Visuble wrong.
    got back in the car and tried to start it, it would not fire, it sounded extremly flooded.. i put and held my foot on the exelarator and it rumbled shoke lost of black smoke and flames came out of the exhust, i though at first there was no fuel getting to the engin, so i replaxed the fuel filter, While i had the filter off i checked the Fuel pump and it seemed to be pupming fuel fine So let it sit there for an hour(to clear any flooding, after the hour i tried to start it, it rumbled shoke and i he lf my foot down for about 30 seconds and it began to run normaly. so i figgered while its going, good time to get it home on the way, it began to over heat not by much but it got pretty dam hot..
    got it home..
    the next day i replaxed the spark plugs one by one, so i would not get the leads muddled up.
    i started it, it stayed on but it ran really ruff so i let it do its ruffness for about 30 seconds and it slowly began to run normaly, let it run for a little, realised the fan was not working (explains the over heating)
    i turned the car off, tryed to start it, sme thing would not start, so i pushed and held the exellerator on for about 30 seconds and it ran normaly,
    i also replaced the Water pump. (it was slowly leaking)
    the next day (today) i repleaced the 02 Sensor, worked for about to goes then started all over agian.
    I put 10 leters though it and some EFI jet cleaner.
    Still nothing
    When its cold it will start but idle ruff.
    there is no engin warning light on.
    Im slowly running out of ideas guy, So if anyone could help me, that would be great
    thanks
    Matty.. FIRST POST, shame its not a good one.
    I have repleaced and check the following
    Radiator
    all 6 plugs
    EFI working correctly
    O2 Sensore
    Battery
    Air Filter
    Carby and Fly Wheel
    Mar 2009
    change your crank angle sensor mate, 9 times out of 10 there the cause of the fault.
    vx s pack II
    Jan 2010
    aLKIDA
    Did you check for codes? Pins 5&6 (Bridge)
    If its a CAS it will tell you when you check for codes
    Feb 2010
    Crank angles?? haha mate.. i have a pretty basic knowledge of cars, most i have learned the past 3 days lol
    What r Crank angles
    And im not sure how to check codes..
    the engin warning light is not on so i though that ment the Computer cant find anything wrong?
    thanks for you help guys
    Mar 2009
    take your car to a mechanic or buy a work shop manual.
    The CAS is a sensor located behind the harmonic balancer when it fails it will cause problems.
    Feb 2010
    ah ok so its here
    Looking from the front of the car, top left of the harmonic balancer (the big pulley at the bottom in the centre) there is a plug, that is the CAS
    =-+--One Life, One Chance--+-=
    Mar 2009
    Feb 2010
    haha ok thanks mate
    thanks for the Quick help
  1. [VR-VS] How To: Fix the VS V6 4 Wire O2 sensor earth problem – Known Holden Problem
    By ephect in forum Holden Commodore How-To's
    Last Post: 17-01-2012, 11:25 PM
  2. LPG problem
    By marshcory in forum General
    Last Post: 28-04-2009, 05:09 PM
  3. vent problem and horn problem
    By plasmid2 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-06-2008, 10:53 PM
  4. Pt 2 cold starting problem - Is my ECU the problem??
    By manfred in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-05-2007, 09:56 PM
  5. amp problem
    By bensta in forum Car Audio
    Last Post: 30-08-2006, 11:47 PM
