Results 1 to 6 of 6
Thread: 304 / ecotec transmissions.
    VS executive
    Jun 2009
    Default 304 / ecotec transmissions.
    do they use the same trans ? if so what would be needed transmision wise if i was too swap out an ecotec for a 304 and keep the same trans?
    just curious.
    VP Executive R-spec
    Jan 2005
    Not the same but CRS have an adaptor so best to ask them. Probably better off to buy a VN/P TH700 for this conversion
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    as foamy said, different bolt patterns, you should be able to find a cheap trans for your conversion
    VS Berlina 3.8
    Dec 2008
    Quote Originally Posted by ephect View Post
    I thought it was input shaft lengths?
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    ones a buick bolt pattern and the other is ... (cant remember)
    VS Berlina 3.8
    Dec 2008
    I'm under the impression that they both have the Chevy Turbo bolt pattern, but the old 308's had the Trimatic.
  1. Transmissions
    By acarmody in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-11-2008, 05:20 PM
  2. transmissions
    By VR 3.8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-03-2007, 11:00 AM
  3. Transmissions
    By tr3nt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-11-2005, 04:48 PM
  4. Transmissions
    By VPower in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-04-2004, 04:57 PM
