hi i was woundering if anyone has a picture of a vs commodores motor with every part pointed and named? im trying to work out what part this is. the 2 pulleys next to each other o nthe fan belt and the bottom 1 of those have seized and trying to work out what it is? thanks
They are just called "idler pulleys" - if one has seized, it's a fair bet the other will also fail soon....may as well also do the tensioner pulley as well. If they are the originals you cannot just change the bearing but need the pulley with bearing (~$26), however if they have been changed you will find the bearing ($8) can be removed from them.
