Results 1 to 4 of 4
Thread: VT break upagrde shims
    VR Acclaim v6..?
    Feb 2008
    Gold Coast
    Default VT break upagrde shims
    Hey all
    was reading somewhere that if you are doing the VT break upgrade you need shims in between the hub and the rotor? Mine seemed to fit up/work perfectly fine (standard VT/VX calipers/rotors)
    Do I or do I not need shims?
    Cars going in for mod plate tommorow so any advice would be appreciated
    cheers
    VR Commodore
    Jun 2005
    yea, u will need shims for this ....
    or u can order vt disc brake to suit vr/vs hub.... without shims..
    VR Acclaim v6..?
    Feb 2008
    Gold Coast
    What function do the shims perform exactly? and what will happen if i dont use them? wheels wil fall off? (literally) haha
    VR Commodore
    Jun 2005
    u can check this site ... VR- VS FRONT ADAPTOR BRAKE SLEEVES, SOLD SINGULAR AS (1)
    if u fit vt brake on ur vr/vs... the disc will be wobbies and noisey when u drive ... so use shim to correctly the center to stop movement ..
    i got vy upgrade on my VR ... no problem with shims .. its run beautiful ..
  1. diff shims????
    By sik-holden in forum General Discussion
    Last Post: 01-09-2009, 02:19 PM
  2. Mag wheel bore shims
    By jonathanvb in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-12-2008, 09:14 PM
  3. Rear Axle Shims ?
    By Rossco in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 23-09-2007, 08:07 PM
  4. where can i buy diff pinion shims??
    By HDT_aero in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2006, 12:49 PM
  5. break pads? price? vt break conversion?
    By stock_vl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 22-09-2005, 06:02 PM
