Tonight I watched my Dad remove the Main circuit breaker from his VS Vacationer,
He then realized that it might not have been s'posed to come out... lol
Whats the easiest way to replace one and best place to get it cheap. ASAP
Thanks
Don't know of any circuit breakers in a VS - do you mean fuse - fusible link or relay?
If it is a fusible link then it will just connect back into the circuit....if you're not sure exactly what it's called, take a digital pix of it...takes all the hassles out of describing things.![]()
Its the yellow 60A Fusible link marked "MAIN" under the bonnet. It sits between a pink and green one. They pulled out fine but the yellow one, dad said, "it was a bit tought but i got it"... lol
As far as i can tell it looks like im replacing the whole socket, Looks like It wasnt meant to come out...
On the VS the main yellow 60A fusible link (the centre one) has a bolt through it that holds it in ,all the others just pull out of their sockets,but not the main one.You have to undo and remove the small bolt that goes through the bottom of the main fusible link to change or remove it.Just below where the fusible links are theres a little black plastic cover/door that unclips and opens up towards the left (of the car),the bolt is behind that little plastic door.
