Results 1 to 8 of 8
Thread: Keeps cutting out
    1993 V.R under construction
    Feb 2010
    Default Keeps cutting out
    Hay my v6 keeps cutting out and some times wont start. When it wont start there is no spark but than it will sometimes fire and run. When it dose run it will just die but it wont bring up a check engine have checkd that and gives us code 12 all good.
    Can the CAS fail and not bring up a check engine or cld it be the coil packs
    Thanks
    vs commodore
    Oct 2009
    Tamworth NSW
    Most likely the CAS.I have seen them fail and not give an error code.They are a fairly common part to fail and can cause problems similar to what you have described.
    vs Berlina
    May 2008
    mine kept cutting out and after like 10 minutes it would restart and did not log any codes replaced cas and all is good now brand new cas cost me $80
    vx s pack II
    Jan 2010
    aLKIDA
    Quote Originally Posted by peowpeow View Post
    Thanks
    If there is no spark it can be the CAS or it can even be the ignition module or the coil pack. (Since you have no fault code)
    Check the EFI relay see if it works. Put the reds on and you should hear the EFI relay click in. If this relay is faulty there will be no power to the ignition module. Also check the fuse to this relay.
    You can test the CAS with a Oscilloscope to see if it produces a constant square wave pattern. But obviously
    you would need a oscilloscope. Other wise you would be guessing.
    Feb 2010
    Thanks for the feed back guys just try the process of animation i think the CAS is going to be a good start for now. I have already checked all the fuses and relays they all seam fine and also changed the fuel pump out
    vs2 berlina 96 3.8 auto hsv plated
    Sep 2008
    brisbane nth
    Mine intermittantly cuts out and won't start sometimes. Have replaced the computer so far. Also new key. Reckon it has something to do with the immobiliser. (the red light under the clock on the radio) Can the immobiliser be disconnected without any ill effects ?
    Kind Rgds
    Dave
    Sep 2008
    brisbane nth
    vr ss
    Jul 2009
    yeah mate pretty simple its only a sensor
  1. Sub Cutting Out
    By markER717 in forum Car Audio
    Last Post: 18-01-2010, 10:08 PM
  2. VN V6 cutting out
    By Shortstuff in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-01-2009, 04:35 PM
  3. VR ss cutting out
    By SERGE in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-03-2007, 12:12 PM
  4. Cutting out
    By Haze in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-07-2006, 05:25 PM
  5. cutting out
    By StatOmaN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-06-2006, 09:16 PM
