Results 1 to 7 of 7
Thread: Whining noise Diff or Auto
    Vs Ute
    Jun 2009
    Default Whining noise Diff or Auto
    hi guys ive got a VS ute with V6 & Auto with 312k kms, and there is a whining noise coming from either the auto or diff im not sure which one, its slowly got worse over time. the with increases its pitch with speed and not with rpm, so that lends me to think its the diff, or like the output shaft of the auto. any ideas? anyone had the same problems? thanks
    rusty91's Avatar
    rusty91 is offline dopespec
    vs 5spd
    Aug 2008
    adelaide
    the diff mate.. could possibly be ur wheel bearings are shot or culd be ur bearings inside the diff like ur pinion bearing or one of the crown wheel bearings . better to jack the car up and then spin it up and have a suss.. even with a long screwdriver to pik the sound more. if its just a wheel bearing then it ant to hard to replace them
    VX II Calais
    Feb 2010
    Skye VIC
    Vs Ute
    Jun 2009
    nope autos fluid is a little discoloured but it still gets all gears wit hno slipping..
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    With the Km's you've done, it's expected and quite normal to have a bit of a whine from the diff.
    My advice only for what it's worth, but I'd just add some Nulon or other diff treatment to the diff and leave it at that. The alternative is trying to get rid of the whine which will cost many dollars and frustration.
    Good Luck.
    vz ss and vs statesman
    Mar 2009
    Vs Ute
    Jun 2009
    yeh 312xxx kms, yep that sounds like a plan il lsee how i go thanks for your advice.
LinkBacks (?)
  1. Transmission - Whining noise
    By Yergin in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-09-2010, 04:04 AM
  2. Bad Whining Noise
    By wassaby in forum General
    Last Post: 06-12-2009, 07:05 PM
  3. Whining Noise
    By theused084 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-05-2006, 08:56 PM
  4. whining noise, plz help!!
    By macdaddy in forum Car Audio
    Last Post: 02-09-2005, 11:43 AM
  5. Whining Noise
    By syth in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 28-05-2005, 01:25 PM
