So i was at my Father in law's place tonight with my 5.0L VS Ute and we got on the topic of LSD's, I said my ute has one, and he begged to differ!
I've had the car over 12 months now and everytime i've let it go lose its spun 2 wheels always never one! So to prove his point he jacked one of the back wheels off the ground and spun it, he said if it had an LSD it wouldn't spin.
So to argue my point we had a VS Clubsport sitting next to mine so we jacked that up too and it did exactly same as mine, the wheel spun. His reply was that they were both single spinners.
SO to argue my point again we jacked up a 2009 VE SV6 Ute which is "Meant" to have an LSD and it did exactly the same as my ute and the clubby. SO . . .
To be 100% positive i said that only Google.com could give us the real answer but i was wrong, i couldn't find anything there so here i am asking the question!
How can i tell if i have an LSD in my ute? I've searched but have not found the info i need through past posts.
I always thought that if i jacked the whole rear end of the car up and spun one wheel as if the car was moving forward the oposite wheel should spin the same direction if you have an lsd fitted . . But **** i've been wrong before so someone please correct me!!
Cheers Jordz!
who cares, if both wheels are spinning assume you got one until you see different.
Dan
Its either a ****ed diff or and LSD, don't think clubbys came with LSD's...
Wow dude awesome answer thanks very mcuh for your help (Sarcasm)
I care beacuse if you've ever tryed to go sidewards around a corner with a single spinner and had it suddenly spin 2 you know that you would be facing the wrong way before you know what the **** has just happened. . .
If i KNOW i have an lsd i know its going to remain true in the arse end! So i won't assume i've got one
If the rear is jacked up on one side, the wheel thats up should need a fair amount of force to turn on a LSD.You shouldnt be able to turn the wheel by hand.(unless the LSD is completely stuffed)You are right,if the whole rear is jacked up,both wheels on a LSD will turn in the same direction when one is turned by hand.A standard open wheel diff's wheels will spin in opposite directions when one is turned by hand.
well from what i know if both wheels spin the same way it is LSD one thing how hard is it to turn the wheel you have jacked of the ground if it is hard you have LSD cause thats what is does on my mums car and it is factory LSD even has it on the back of the diff HIGH PERFORMANCE LSD and when you jack one wheel of the ground it spins but it wont free spin needs to be turned by hand and iit is hard to turn
To test a LSD for wear you jack up one wheel,handbrake off,trans in neutral,and you connect a torque wrench to the axle and it should take a minimum of around 60 - 70 Nm to turn the axle.
Alot of conflicting views...
I got a better one for you, open up your diff and see for yourself!
simple test... find a nice concrete pad in a private area... foot hard on brake select 1st gear, throttle flat to floor... if you start to go sideways and both wheels have smoke pooring off them its lsd!!! if its just one wheel smoking single spinner..![]()
I think "High Performance" just means the gears have been shot peened. The thread below says it has to mention "LSD" somewhere.
The ZOMGWTFBBQLOL how to tell if i have an LSD thread:
Even if it is LSD, there's a good chance it will have worn out by now, Holden LSD's were never the best.* Jack up the rear of your car so both rear wheels are in the air.
* Make sure the car is supported safely and the front wheels chocked.
* Place the car in neutral with the handbrake off.
* Turn one of the rear wheels as if the car is driving forward. If the other wheel turns the same way, chances are you have an LSD - If the other wheel turns the opposite way, chances are you have an open diff.
If you have an LSD, chances are you will have a tag hanging off the oil filler plug located on your doff center cover. the tag will say "[HIGH PERFORMANCE] LSD use approved lub only" - or something to that extent. If the tag says "HIGH PERFORMANCE" (or something like that, with NO mention of LSD...) then it is likely that it's NOT an LSD.
Both of these.. If you jack up both wheels and spin one wheel both will spin the same way with lsd or a spooled diff. Single spinner will spin opposite ways. Drop one wheel onto the ground and spin again.. If it spins(should be firm) it's lsd if not it's a spooled diff.
