Hi All.
Does anyone know the position specs of the wagon's spoiler/dust deflector. Any one know the specs of where it's to go for a vs wagon?
ie. 50mm from top and 400m in from side of tailgate etc
We need to know where to position the screw holes for it etc
Also any other relevant info/advice we should know would be helpful.
We have called Holden and they don't know as it's obsolete.
Thanks.
I'll check mine out and try and let you know tomorrow (Sunday)
Ron
Mmmmm V8
Thanks for that, much appreciated.
OK what I have done is taken measurements from under the hatch i.e. where the holes are drilled to access the screws to screw down the deflector. From the top I'd suggest to make 2 dowels with sharpened ends (perhaps from nails) to fit snugly in the screw holes of the mounting points on the deflector so they just poke out. I would then carefully place the deflector on the hatch and have the dowels "mark" the surface so you know where to drill the holes. The ends of the deflector are simply held down with some black coloured mastic type adhesive. Hope this helps.
Ron
Mmmmm V8
Thanks very much for posting that, it will be a great help.
No probs...good luck![]()
Mmmmm V8
