Results 1 to 17 of 17
Thread: Vr commodore auto leaving fluid
    Vr Executive s2
    Jan 2010
    Default Vr commodore auto leaving fluid
    Hey all my Vr has decided to start leaking oil out of the front between the tranny and the engine its definitly auto fluid.
    it drives perfect but leaks can anyone give me any suggestions on what to do and how to fix it or am i better of just getting a 2nd hand gear box.
    91 vn s
    Jun 2009
    Adelaide, SA
    its probably just a seal mate, one of my mate's cars had a similar problem, then it began revving out, he lost power to his wheels then (both) seals went kaput and he lost ALL his trans fluid, cost him like $500 or something :S
    it could be a hose clamp, maybe a split in the hose..
    try wiping down the surfaces clean (if u can) then check a bit later to see where exactly the fluid is leaking from - theres a start
    Vr Executive s2
    Jan 2010
    ive had a look at it earlier today, its leaking out of were the auto and engine connect mainly out of the inspection plate, well beside the inspection plate
    91 vn s
    Jun 2009
    Adelaide, SA
    ok well then i dont think i would have much of a clue then as i dont know much about anything really, I am just a novice whos heard stories. sorry i couldnt b of any further help, hope u get it sorted out soon though
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Take it to a transmission shop before it gets any worse and your forced to do a rebuild.
    Vr Executive s2
    Jan 2010
    transmission shop recons just to rebuild it to be sure and wants 1500 bucks
    wraith's Avatar
    '95 VR Series II
    Sep 2008
    Demonicaland
    As per PM mate put up your location. Some one may know a person worth going to.
    Vr Executive s2
    Jan 2010
    I live in hervey bay queensland and nilly every machanic and auto shop is a rip off merchant unfortunitly
    Mar 2009
    sounds like the front seal has gone, easy seal to change but unfortunately you have to take the gear box out to change it.
    vr series 2 v6
    Oct 2009
    nsw
    yea def sounds like a seal, worst case is tourque converter is leakin fluid, but then you would have change in your cars general driving
    Vs eco 3.8, extractors, 2.75" exhaust, roller rockers, cammed, bored out 20, t5 manual, rolling on king springs all way round with monroe gt shocks all way round, every door has a ding but looks can be very deceaving
    bloodyricho's Avatar
    bloodyricho is offline Bloody Richo
    Vr V6 Equipe (hare) and VE SV6 (tortise)
    Dec 2009
    littleton nsw
    yep $100 fix $20 for seals and $80 for beer - get a mat to give you a hand can be done with floor jack and a 1/2 inch socket set. just a hint drain box first saves big mess later
    Making and running DUAL CHIPPED ECU SINCE 2010
    RX25SE's Avatar
    RX25SE is offline Real cars are steel cars.
    vsII acclaim wagon
    Jan 2009
    Converter seal is leaking. Trans out to fix.
    Check the converter bushing (bearing), if this is worn the new seal will leak.
    If the bush is worn you may see grooves worn in the back of the converter (the bit that goes into the trans).
    Vr Executive s2
    Jan 2010
    Vr Executive s2
    Jan 2010
    Bloodyricho only 1 problem there lol i kinda hate beer but ill happily polish of a bottle of bourban doing it
  15. #15
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    If you don't want the hassle of pulling it apart to put a new seal in, you could throw in a can or two of "auto trans seal conditioner''....this usually will soften the seals and make them seal better....it usually works and reduces leaks down to a drip or two. Buy a better brand....Nulon seem good.
  16. #16
    rusty91's Avatar
    rusty91 is offline dopespec
    vs 5spd
    Aug 2008
    adelaide
    so its not the rear main seal on the back of then engine? so u are loosing trans fluid like u checked the dipstick
  17. #17
    Vr Executive s2
    Jan 2010
    ive checked it. its definitly auto fluid
  1. auto fluid use different to dex3
    By Zuicider in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-02-2009, 01:48 PM
  2. Auto fluid checking Question
    By VS_Pete_1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-12-2008, 04:59 PM
  3. Brake Fluid and Auto Trans Fluid.
    By Melchior3 in forum General
    Last Post: 20-02-2006, 11:49 AM
  4. Draining transmission fluid on an auto
    By Scooter79 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-08-2005, 02:52 PM
  5. VR V6 Auto Fluid Check?
    By Driver 111 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-07-2005, 05:32 PM
