Results 1 to 6 of 6
Thread: Coolant leaking from rocker cover
    StockoVRWagz's Avatar
    StockoVRWagz is offline Formerly White50L
    '94 VR Wagon
    Feb 2008
    Northern Suburbs, SA
    Default Coolant leaking from rocker cover
    I have a VR V6, and have noticed on the drivers side, coolant bubbling out a pin-sized hole in the rocker cover gasket on the top near the injectors.
    Is it as simple as replacing the gasket, or is there something else inside that will need replacing? I did a search but couldnt find much.
    Oil and coolant are fine, car runs fine too.
    Cheers,
    Paul.
    VX SS M6
    Jun 2005
    '94 VR Wagon
    Feb 2008
    Thanks for that, Ill have another search for that on here. Also will this mean the rocker cover gasket will also need replacing now too?
    Cheers.
    '94 VR Wagon
    Feb 2008
    sik_dose is offline Hybrids. Cars for fools.
    1986 VL Calais 5 Speed
    Feb 2010
    if its leaking, dont worry about any noises just replace the gasket. drain the cooling system by removing the bottom radiator hose, take off the inlet manifold renew gaskets, use some gasket goo to make sure it seals up nice and tight then torque it all down, refill coolant and bleed the system.
    VK SL 5spd
    Sep 2009
    Wagga Wagga
    Quote Originally Posted by sik_dose View Post
    Couldnt put it any simpler myself , very easy job to do.
  1. leaking rocker cover gaskets
    By GM GEN3 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-02-2010, 12:46 PM
  2. rocker cover gaskets leaking
    By VTS07 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-04-2009, 10:59 PM
  3. Rocker Cover - Oil
    By COMMY VP 666 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-12-2008, 01:16 PM
  4. coolant leaking timing cover temporary fix???
    By NOGEN 3 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-04-2008, 12:36 PM
  5. 202 Rocker Cover
    By vkberlina in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-06-2004, 11:26 PM
