Results 1 to 6 of 6
Thread: steering groaning noise ( again )
    VS executive
    Jun 2009
    Default steering groaning noise ( again )
    can someone please post a pic of where im supposed too oil up to get rid of the groaning noise that comes from the steering column?
    i was told its at the edge of the firewall but theres housing or someshit there , also is wd40 ok?
    vnss
    Jan 2005
    s.e melb
    its a grommit in the firewall where the steering shaft comes through.
    sorry i dont have pics
    use grease, wd will just dry out eventually
    VS executive
    Jun 2009
    so i have to take off the housing on the engine bay side to get at it then?
    VZ R8. VS II L67 M5. VT International Calais L67.
    Aug 2008
    NSW South Coast
    No you dont have to take anything apart. Shine a torch on the drivers side firewall and you should see where the steering column comes through. It has a rubber grommet/boot around it. Best thing to use in my opinion is the aerosol spray grease. Need to try get it as far up the rubber boot as you can. Hope that helps.
    VS executive
    Jun 2009
    vnss
    Jan 2005
    s.e melb
    i did it with a screwdriver from under the car.
    if you do it this way please use car stands or drive it on ramps.
  1. Steering Wheel Groaning
    By melissanjosh in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-01-2008, 11:06 AM
  2. Steering column groaning noise
    By ozzie_online88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-02-2006, 03:12 PM
  3. Variatronic steering groaning noise
    By vsuterus in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-02-2006, 08:40 AM
  4. Groaning noise in VT 5spd
    By vtss5spd in forum V8 Development and Modification
    Last Post: 09-01-2006, 01:03 PM
  5. groaning noise from left hand side
    By hdt238 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-06-2005, 11:55 PM
