Results 1 to 11 of 11
Thread: Defected, needs full roady. what to expect?
    vs berlina s2
    Feb 2009
    Default Defected, needs full roady. what to expect?
    97 vs series 2 180000km...needs full roady......what parts am i expecting to find that are worn and torn???? its had a new power steering rack new tie rod ends. new radius rod bushes. its been slammed for about 12 months before that it was stock as and had no underbody maitanance.
    GetToDaChopa is offline Blues Brother # 2
    The Blues Mobile
    Dec 2008
    Western Sydney
    Depends what they find. No one here will definitely know whats broken on your car except the people who will look at it.
    vs berlina s2
    Feb 2009
    i should say...its never had underbody work...no bushes or anything except what listed. im to the understanding the vs has some common problems. and for the amount of km on im trying to work out roughly how long these parts last etc.
    VS L67 Statesman
    Oct 2006
    Melbourne, VIC
    vs berlina s2
    Feb 2009
    Mar 2009
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    In Qld you need to look out for frayed seat belts, slow retracting seatbelts, 3 of 4 power windows must work, all brake lines/calipers/hoses etc must be bone dry, same for power steering, not drop oil on floor whilst being tested, usual lights/wipers etc etc. At 180K all bushes should still be OK.
    You may find that your state roads authority has a website which lists items to inspect - qld has one.
    Good Luck.
    vs berlina s2
    Feb 2009
    defected on . tyres. uneven ware i knew this i was going to book it in monday i found they were a bit bald on friday too low apprently. and no suspention travel.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by fonzo View Post
    ( too low apprently. and no suspention travel.
    I gather that's what "slammed" means....in that case I would guess you'd need to take it back as near as possible to factory standard.
    In Qld, you can go to an authorised inspection station, which is another name for a garage and get a report on what needs doing for a RWC...this gives you more breathing space as it's not official. The cost of this inspection is usually subtracted from the cost of the official RWC.
    2005 VZ SV6
    Jun 2009
    Australian Crapital Territory
    vs berlina s2
    Feb 2009
    meh, upper and lower trailing arms. bit of mirror glass. few bulbs. .
  1. what db can i expect
    By vnskidder in forum Car Audio
    Last Post: 22-02-2008, 11:14 AM
  2. What should I expect
    By Nanos in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-12-2007, 06:39 PM
  3. VZ S Ute - What to expect?
    By Lemon in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 01-05-2006, 08:37 PM
  4. What can I expect?
    By vick58 in forum General
    Last Post: 04-02-2005, 11:57 PM
  5. How Much Should I Expect To Pay?
    By lil_bonk_frog in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-05-2004, 10:14 PM
