Results 1 to 7 of 7
Thread: Vs running ritch?
    VS ute
    RefleX v1.2 Champion!
    Aug 2009
    Default Vs running ritch?
    Hey,
    My v6 vs has been running poorly lately (Sounds like it could be missing, runs really crap until its warmed up, when i crank it over it sounds like its struggling to start, smells like fuel and just dosent sound right) so for some reason i decided to take the top off the intake manifold, now i know its normal for it to be a little black with carbon deposit's etc, but as soon as i took the lid off the intake manifold i could smell fuel, and the runners and inside of the lid looked like it was covered in oil/fuel, i attached a picture but it was off my phone so its kinda crappy,
    i checked on the other side of the throttle body and it was pretty clean/no oil or anything..
    i was gonna take the spark plugs out tomorrow and check to see if they were all black too,
    but i didnt think it was really possible for a fuel injected car to run ritch unless i modified the memcal? or could a bung sensor be at fault?
    Thanks
    My 5SPD VS UTE!! Now wrecking
    Quote Originally Posted by Grennan View Post
    Aggravated Burnout.... How is that different to a normal burnout, does the guy have a frowny face? Seriously get ****ed.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Do a codes check as it's possible one of the oxygen sensors is buggered on one side and telling the ECU the mix is weak. Another possible is the coolant temp sensor which tell the ECU the engine is cold so it needs a rich mixture. But first I'd do the codes check.
    Checking error codes VR/VS (Revised)
    VS ute
    Aug 2009
    checked error codes and only got 12...
    but ive heard that the o2 sensors dont spit a code until they are completly farked?
    either way im sure they could do with being replaced anyway..
    vs commodore
    Oct 2009
    Tamworth NSW
    The oxygen sensors dont even do anything while the engine is cold.The ECU ignores them until the engine is up to temp.So they wont effect the running of the engine when its first started up from cold.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by Brett_jjj View Post
    I didn't even think of that Brett.
    How about worn injector(s) on that bank leaking/dribbling overnight into the inlet manifold leaving a small pool of fuel in the manifold and a petrol smell - engine starts, plugs that are wet don't fire etc till dry. When warm runs OK.
    VS ute
    Aug 2009
    Quote Originally Posted by hako View Post
    hmm, injectors are less than 6 months old.. i have ordered some top gun leads so i will see if they make a difference.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Here is a good link for testing injectors and talks about them leaking etc.
    testing injection
  1. VE 6L V8 running on LPG.?
    By FPV 4 T in forum VE Holden Commodore (2006 - ?)
    Last Post: 22-10-2010, 07:23 AM
  2. vk problems blowing smoke running to ritch
    By dazz9 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-01-2010, 06:20 PM
  3. sub not running
    By VY.abercrombie in forum Car Audio
    Last Post: 30-04-2009, 09:43 PM
  4. VR Engine light stays on running running alittle rough
    By AJKoo1 in forum General Discussion
    Last Post: 07-09-2006, 01:08 AM
  5. running hot...
    By Torquen in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-04-2006, 11:37 PM
