Results 1 to 12 of 12
Thread: Battery flat after 2 days!
    1994 VR SS
    Sep 2009
    Question Battery flat after 2 days!
    My battery goes flat after 2 days - Its not the internal lights or the boot light/s
    and it's not the stereo. What ever it is it's drawing nearly 3 amps! (when checked at the battery with key off). I'm no auto electrician so dont know where else to look!
    It has a dynatron alarm, could this be the cause? If so does any one know how to
    disconnect it? because I know it immobilises the car.
    wamboin23's Avatar
    wamboin23 is offline Donating Member w/ Boost
    VS Calais - L67 + T5 | VR Acclaim V6
    Apr 2009
    Wamboin, NSW
    unplug the plug on the regulator of the alternator and see if it goes away.
    sounds like the fault may lie with the alternator.
    TheForgotten's Avatar
    TheForgotten is offline only human......
    VR EXEC
    Dec 2005
    quarantine
    my vote's in the diode
    Quote Originally Posted by MY-42-VT
    if they didn't have that thing between there legs we'd laugh and throw rocks at them
    WTB VR/VS FACTORY HEADUNIT BRACKETS PM ME
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Immobilisers can fail and cause your problem. To test whether the alternator has bad diodes you will need to remove the thick cable that is bolted to the rear of the alternator. Be careful when doing and don't let the cable earth out as it is unfused. If it sparks when removed that will indicate the diodes are bad.
    Dec 2009
    If nothing in the car is running like lights etc then it's probably a field diode in the alternator.
    1994 VR SS
    Sep 2009
    vr ss
    Jun 2005
    hay guys i have the same problem on my ss i will let u know how it goes once battery is recharged
    hmmmmmmmmmm
    vr ss
    Jun 2005
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    I wouldn't replace the alt just because the battery is flat...first I'd decide if maybe the battery is past it's use-by-date. then if the red charge light has been lit I'd do some checks to see if it is repairable. If the red light is not lit when running I would then use a multimeter to check that the voltage across the battery at about 1000rpm was above 14V....if it wasn't I'd check the brushes/regulator.
    But the first thing is to find out why your battery is flat. Good Luck.
    vr ss
    Jun 2005
    yea i thought it was the battery first so i replaced that but same prob ill recharge battery then disconnect the wire and see how i go, its only going flat while car is turned off all lights are off and i have disconnected amp ect
    hmmmmmmmmmm
    vs commodore
    Oct 2009
    Tamworth NSW
    VS Executive
    Nov 2008
    Wollongong
    Get someone to sit with the multimeter outside the car while you pull each fuse. Once the reading goes down you will know what circuit the current is being drawn from. That should give you a decent clue to where the problem lies.
  1. flat battery, how do i get in?
    By 2LOUD2OLD in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-01-2011, 01:57 PM
  2. flat battery
    By Petes VY in forum VY Holden Commodore (2002 - 2004)
    Last Post: 03-07-2009, 08:54 PM
  3. Flat Battery
    By tr3nt in forum Electrical Wiring / Questions
    Last Post: 31-05-2009, 07:07 PM
  4. VS-Battery keeps going flat
    By evanthe mac in forum Electrical Wiring / Questions
    Last Post: 29-09-2005, 09:14 PM
  5. Flat Battery
    By Randy18 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-03-2005, 12:38 PM
