Results 1 to 9 of 9
Thread: Light scratches in Windscreen
    Vs Berlina
    Mar 2009
    Default Light scratches in Windscreen
    Hi all, I blew a wiper today & have slight scratching on the screen. Anyone know if or how to get it out, polish of some sort perhaps????
    Thanks in advance.
    2004 XR6T & 1990 VN dragcar project
    Jan 2010
    Bendigo, Victoria
    Wet steelwool is your best bet.
    Or some 1200grit wet'n'dry might work also.
    Ozzie's Avatar
    Ozzie is offline JCCC Warrnambool
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    yea as neet suggested.
    though it depends on how light it is.
    might get away with some cut n polish.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    As long as the scratch isn't too deep the best method is to use toothpaste on a dry cloth and rub in a circular motion. Whitening toothpaste is best. Jewellers rouge is what the glass people use but not everyone has this at home.
    I personally would not use steel wool or wet and dry - they are too abrasive and will leave a surface covered in tiny scratches.
    Good Luck.
    Jan 2010
    Bendigo, Victoria
    WET steel wool works perfectly fine. Obviously you wouldn't use dry steelwool.
    We used to get alot of cars that had scratched windscreens and FROM EXPERIENCE, not personal opinion it works perfectly fine, and in no way leaves scratched in the surface
    tivoom's Avatar
    tivoom is offline pimpin pizza wagon
    VR S2 Wagon
    Jan 2009
    newcastle
    Ill try this today but I have BAD marks in mine I have tried auto glym glass polish and it didn't do shit so ill get back to you to night
    Ozzie's Avatar
    Ozzie'z 97 VT
    Jul 2008
    Warrnambool
    Quote Originally Posted by tivoom View Post
    If their really bad like mine then the windscreen needs replacing.
    Although im sure obriens glass should be able to fix it.
    They do a good job of hiding chips so i dont see why not.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by neet_wagon View Post
    I'll try some steel wool and see how it goes on glass - I'll use the really fine 0000 grade and not the pot scrubbing type which apparently leaves "micro scratches" (Google search).
    Thanks for the tip.
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    I used steelo soap pads once and ended up with many fine scratches.
    MY RIDE
  1. scratches
    By AdAdrian in forum General
    Last Post: 26-01-2010, 10:32 PM
  2. Rear Windscreen Brake Light
    By CSP in forum VE Holden Commodore (2006 - ?)
    Last Post: 12-10-2007, 07:33 AM
  3. best product to get light scratches off my paintjob
    By djvsa in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-01-2007, 06:11 PM
  4. Windscreen scratches
    By newo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-12-2005, 11:51 AM
  5. Scratches
    By jamiekratin in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-09-2005, 07:59 PM
